Subject: acctst failure
Date: Fri, 15 Sep 2017 20:40:12 +0000
Hi
I am running the acctst (r3.14.12.5) on a softIOC (REHLv7).
acctst timerperiod 2 1 10 1
where timerperiod is an analog output record with DTYP of Soft Channel
Everything runs fine up until the caTaskExitTest (see below).
Any ideas as to why ca_task_exit() would cause a segmentation fault.
Thx,
Al
verifyAnalogIO {} 0.019500 sec
verifyAnalogIO {} 0.017648 sec
multiSubscriptionDeleteTest {...} 0.080886 sec
singleSubscriptionDeleteTest {..........} 0.842084 sec
channelClearWithEventTrafficTest {} 27.055007 sec
monitorUpdateTest {...} 1.107345 sec
verifyHighThroughputRead {} 0.003613 sec
verifyHighThroughputWrite {} 0.000780 sec
verifyHighThroughputReadCallback {} 0.101164 sec
verifyHighThroughputWriteCallback {} 0.101897 sec
verifyBadString {Test fails if stim "8" isnt roughly equiv to resp "8.000000"
} 0.000064 sec
verifyMultithreadSubscr {.} 0.097351 sec
CA pend event delay = 1.000000 sec results in error = 0.012294 %
CA pend event delay = 0.100000 sec results in error = 0.111641 %
CA pend event delay = 0.250000 sec results in error = 0.051082 %
ca_client_context at 0xf0bcd0 pndRecvCnt=0 ioSeqNo=4371
verifyConnectionHandlerConnect {........................................} 1.002006 sec
verifyBlockingConnect {........................................} 0.370005 sec
verifyClear {} 0.000008 sec
verifyReasonableBeaconPeriod {Beacon anomalies detected since program start 7
Estimated beacon period for channel ss1:om1s:timerperiod = -1.79769e+308 sec.
busy: receive watchdog for "ss1:om1s:timerperiod" expires in 29.9219 sec.
inactive: receive watchdog for "ss1:om1s:timerperiod" expires in 29.9887 sec.
} 30.001885 sec
caTaskExitTest {Segmentation fault (core dumped)
Re: acctst failure Andrew Johnson
Prev: QtQuick + EPICS PV = CSDataQuick Wang Xiaoqiang (PSI)
Next: Modbus R2-10-1 available Mark Rivers
Next: Re: acctst failure Andrew Johnson
