Subject: Modbus R2-10-1 available
To: Mark Rivers <[email protected]>, epics Techtalk <[email protected]>
Date: Fri, 15 Sep 2017 20:44:03 +0000
Folks,
Just after releasing R2-10 this morning I realized there was an important outstanding pull request.  I have merged it and done some testing, so I am now releasing 2-10-1.
This is the new item from the release notes:
- Previously the Modbus/TCP transaction ID was set to 1 on writes and ignored on reads.
  Now the Modbus transaction ID is incremented by 1 on each message sent by the driver.
  On the reply the driver waits until a message with the correct transaction ID is received, ignoring messages with any other transaction ID.
  This is more robust, especially for Modbus/UDP links. Thanks to Eric Norum for this.
This change assumes that the Modbus server correctly implements the Modbus/TCP specification which requires it to echo back the transaction ID that it receives.  I have tested this on several Modbus servers.  If in the future we find that there are non-compliant Modbus servers then we can add an option to disable the check on the received messages.
The home page is here:
http://cars.uchicago.edu/software/epics/modbus.html
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The repository is on Github:
https://github.com/epics-modules/modbus
Prev: acctst failure Al Honey
Next: Re: acctst failure Andrew Johnson
Prev: Re: acctst failure Andrew Johnson
Next: New versions of ipUnidig, ip330, and dac128V modules have been released Mark Rivers
