Subject: New versions of ipUnidig, ip330, and dac128V modules have been released
To: EPICS Tech-Talk <[email protected]>
Date: Sun, 17 Sep 2017 12:45:50 +0000
Folks,
ipUnidig R2-11
Release notes:
- Fixed bug in drvIpUnidig::pollerThread(). It was not taking the lock when accessing the asynPortDriver parameter library.
  This was causing occassional IOC hangs and crashes, particularly when using the filterDriver.st SNL program with SPEC.
- Removed parameter counting and NUM_UNIDIDIG_PARAM argument to asynPortDriver constructor. These are not needed in asyn R4-32.
- Added new iocsh directory with EXAMPLE_ipUnidig.substitutions and IpUnidig.iocsh files. Thanks to Keenan Lang for this.
- Moved repository from SVN at APS to Github.
- The Makefile, CONFIG, CONFIG_SITE, and RULES* files in the configure directory have been updated to the versions in the template files in EPICS base 3.15.5.
  The new versions are better suited to site-specific customization.
https://github.com/epics-modules/ipUnidig
ip330 R2-9
Release notes:
https://github.com/epics-modules/ip330
dac128V R2-9
Release notes:
- Removed parameter counting and NUM_PARAMS argument to asynPortDriver constructor. These are not needed in asyn R4-32.
https://github.com/epics-modules/dac128V
Prev: Re: acctst failure Andrew Johnson
Next: Action Button in Display Builder xus
Prev: Modbus R2-10-1 available Mark Rivers
