Subject: Basic String Concatenation in EPICS
Date: Fri, 6 Oct 2017 17:11:48 +0000
Is there a way to concatenate two strings in EPICS?
Googling “concatenate strings epics” brings up sCalcout. I tried using sCalcout, but it insists on converting the inputs to floating point values and this causes some problems:
record (stringin, "$(Sys)$(Dev)OLFQ")
    field (DESC, "Open Loop Frequency")
    field (DTYP, "Soft Channel")
    field(SCAN, "Passive")
record (stringin, "$(Sys)$(Dev)MVOL")
    field (DESC, "Open Loop Steps")
record (scalcout, "$(Sys)$(Dev)Result")
    field(SCAN, "1 second")
    field(INPA, "$(Sys)$(Dev)MVOL")
    field(INPB, "$(Sys)$(Dev)OLFQ")
    field(CALC, "STR(A)+STR(B)")
If I set $(Sys)$(Dev)OLFQ to 1, and $(Sys)$(Dev)MVOL to 2, the result I get in SVAL is “1.00002.0000”. Is there any way to get just “12”? If I do it without the STR around A and B, it numerically adds A and B and I get “3.0000” for SVAl. Is it not possible to just concatenate two string PVs in epics?
Alex
Re: Basic String Concatenation in EPICS Mooney, Tim M.
Prev: Re: Asyn GPIB proto file exception @writetimeout Zimoch Dirk (PSI)
Next: Re: Basic String Concatenation in EPICS Mooney, Tim M.
Prev: Re: Writing PVs from an amalgamated structure Ralph Lange
