Subject: Re: Asyn GPIB proto file exception @writetimeout
Date: Fri, 6 Oct 2017 17:07:55 +0000
Hi James,
I will have a look at the @writetimeout handler after the ICALEPCS.
The reason why you do not see the @replytimeout handler executing is that the protocol already bails out in write and never gets to the point where it would wait for a reply.
Can you try to print a stack trace of the crashed ioc (e.g. using gdb) and send it to me?
Cheers
Dirk
> Am 06.10.2017 um 17:40 schrieb "[email protected]" <[email protected]>:
> Hey hey!
> I have a device on my Linux IOC, using Asyn GPIB.  The device works on the
> IOC and, connected with EDM - is controllable.
> When the device is turned off I get an error message:  asynError in write:
> GPIB0 writeGpib failed ENOL 2: No listeners
> The function in the proto file uses exception @replytimeout, but that
> never executes,  which I would expect (I queried a device, it's not there,
> I should have a timeout). This works on TCP/IP devices, just not GPIB.
> Does anyone have any thoughts, or hacks, or updates on getting GPIB
> exceptions to run the proto file exception commands?
> Also when I try using the @writetimeout exception to more closely mimic
> the error message, the IOC crashes on boot, not even an IOC command
> prompt, which looks like a separate problem, any help on that would also
> be appreciated.  Error message is:
> A call to 'assert(dbLockIsInitialized)'
>    by thread 'cbLow' failed in ../dbLock.c line 239.
> EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
> Local time is 2017-10-06 08:13:40.495885987 PDT
> Please E-mail this message to the author or to [email protected]
> Calling epicsThreadSuspendSelf()
> Thread cbLow (0x9a12518) suspended
> Cheers
> James Larsson
Re: Asyn GPIB proto file exception @writetimeout Mark Rivers
Asyn GPIB proto file exception @writetimeout jlarsson
Prev: Writing PVs from an amalgamated structure Iain Marcuson
Next: Basic String Concatenation in EPICS Sobhani, Bayan
Prev: Asyn GPIB proto file exception @writetimeout jlarsson
Next: Re: Asyn GPIB proto file exception @writetimeout Mark Rivers
