Subject: Re: Asyn GPIB proto file exception @writetimeout
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 6 Oct 2017 20:40:44 +0000
You should also tell us what version of asyn and streamDevice you are using.
Sent from my iPhone
> On Oct 6, 2017, at 7:08 PM, Zimoch Dirk (PSI) <[email protected]> wrote:
> Hi James,
> I will have a look at the @writetimeout handler after the ICALEPCS.
> The reason why you do not see the @replytimeout handler executing is that the protocol already bails out in write and never gets to the point where it would wait for a reply.
> Can you try to print a stack trace of the crashed ioc (e.g. using gdb) and send it to me?
> Cheers
> Dirk
>> Am 06.10.2017 um 17:40 schrieb "[email protected]" <[email protected]>:
>> Hey hey!
>> I have a device on my Linux IOC, using Asyn GPIB.  The device works on the
>> IOC and, connected with EDM - is controllable.
>> When the device is turned off I get an error message:  asynError in write:
>> GPIB0 writeGpib failed ENOL 2: No listeners
>> The function in the proto file uses exception @replytimeout, but that
>> never executes,  which I would expect (I queried a device, it's not there,
>> I should have a timeout). This works on TCP/IP devices, just not GPIB.
>> Does anyone have any thoughts, or hacks, or updates on getting GPIB
>> exceptions to run the proto file exception commands?
>> Also when I try using the @writetimeout exception to more closely mimic
>> the error message, the IOC crashes on boot, not even an IOC command
>> prompt, which looks like a separate problem, any help on that would also
>> be appreciated.  Error message is:
>> A call to 'assert(dbLockIsInitialized)'
>>   by thread 'cbLow' failed in ../dbLock.c line 239.
>> EPICS Release EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$.
>> Local time is 2017-10-06 08:13:40.495885987 PDT
>> Please E-mail this message to the author or to [email protected]
>> Calling epicsThreadSuspendSelf()
>> Thread cbLow (0x9a12518) suspended
>> Cheers
>> James Larsson
Asyn GPIB proto file exception @writetimeout jlarsson
Re: Asyn GPIB proto file exception @writetimeout Zimoch Dirk (PSI)
Prev: Re: init function in device support Thomas, Patrick
Next: Re: Writing PVs from an amalgamated structure Johnson, Andrew N.
Prev: Re: Asyn GPIB proto file exception @writetimeout Zimoch Dirk (PSI)
Next: Re: Asyn GPIB proto file exception @writetimeout Dirk Zimoch
