Subject: Re: caputRecorder make error
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Thu, 19 Oct 2017 00:03:14 +0800 (GMT+08:00)
It seems your EPICS_HOST_ARCH environment variable is not set.
Dirk
Am 18.10.2017 um 15:52 schrieb l123173 <[email protected]>:
Hi all,
    I have installed synapps_5_8, base-3.15.3, centos 7.
    Base was ok. When I make synapps, caputRecordes has error, so I downloaded the newest caputRecorder from github( https://github.com/epics-modules/caputRecorder )
   Then I modified RELEASE in caputRecorder.
but  it said:  (base was in /opt/base-3.15.3)
[root@localhost caputRecorder-master]# make
/opt/base-3.15.3/configure/CONFIG:56: /opt/base-3.15.3/configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target `/opt/base-3.15.3/configure/os/CONFIG..Common'.  Stop.
How could I fixed it?
Thans,
Li xing
Re: caputRecorder make error Shen, Guobao
caputRecorder make error l123173
Re: caputRecorder make error Zimoch Dirk (PSI)
Prev: Re: caputRecorder make error Zimoch Dirk (PSI)
Next: Re: caputRecorder make error Shen, Guobao
