Subject: Re: caputRecorder make error
To: l123173 <[email protected]>, "Zimoch Dirk (PSI)" <[email protected]>
Date: Wed, 18 Oct 2017 16:56:32 +0000
Can you post your modified RELEASE file of caputRecorder?
Did you modify your setting of EPICS base?
If not, the only setting you have to change is the EPICS_BASE.
Either the one comes with synapps, or the one from github should be compiled as it is.
Guobao
From: <[email protected]> on behalf of l123173 <[email protected]>
Date: Wednesday, October 18, 2017 at 11:06 AM
To: "Zimoch Dirk (PSI)" <[email protected]>
Hi Dirk.
I have set it in ~/.bash_profile
发自网易邮箱大师
On 10/18/2017 23:59, Zimoch Dirk (PSI) wrote:
It seems your EPICS_HOST_ARCH environment variable is not set.
Dirk
Am 18.10.2017 um 15:52 schrieb l123173 <[email protected]>:
Hi all,
    I have installed synapps_5_8, base-3.15.3, centos 7.
    Base was ok. When I make synapps, caputRecordes has error, so I downloaded the newest caputRecorder from github( https://github.com/epics-modules/caputRecorder )
   Then I modified RELEASE in caputRecorder.
but  it said:  (base was in /opt/base-3.15.3)
[root@localhost caputRecorder-master]# make
/opt/base-3.15.3/configure/CONFIG:56: /opt/base-3.15.3/configure/os/CONFIG..Common: No such file or directory
make: *** No rule to make target `/opt/base-3.15.3/configure/os/CONFIG..Common'.  Stop.
How could I fixed it?
Thans,
Li xing
caputRecorder make error l123173
Re: caputRecorder make error Zimoch Dirk (PSI)
Re: caputRecorder make error l123173
Prev: Re: caputRecorder make error l123173
Next: Looking for a Beckhoff PLC Expert!! Wallace, Alex
