Subject: Re: EPICS base R3.15.5 special CONFIG and RULE files
To: "'[email protected]'" <[email protected]>
Date: Fri, 10 Nov 2017 13:38:26 +0100
[sorry for possible duplicates, forgot to reply to the list]
On 11/09/2017 11:59 PM, Luchini, Kristi L. wrote:
> However, my RULES file from R3.14.12, now either generate errors
> during the build or it will generate an empty alhConfig which it
> installs in to $TOP/alh.
> Is there an example of a RULES_<file type> that I can used. Below is
> what I am using, which clearly is wrong.
> File configure/Makefile
> CHECK_RELEASE = YES
> TARGETS = $(CONFIG_TARGETS)
> CONFIGS += $(subst ../,,$(wildcard $(CONFIG_INSTALLS)))
> CFG +=CONFIG_ALARMS RULES_ALARMS
> CFG +=CONFIG_PROTOS
> include $(TOP)/configure/RULES
> File: configure/CONFIG_ALARMS
> FILE_TYPE+=ALHS
> INSTALL_ALHS = $(INSTALL_LOCATION)/alh
This is no longer needed as there are now a similar definitions in base,
which use ALH, not ALHS. You can keep you won FILE_TYPE, though, since
due to the different name there is no conflict.
> File:  configure/RULES_ALARMS    --- similar to R3.14.12   RULES.Db
This is a mistake. RULES.Db is an overly complicated monster. I wish
there was a way to completely disable it.
All you need is the vpaths:
> vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(ALH))
> vpath %.alhsubstitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
however, these are not good. I would rather use
vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
(Presumably alhsubstitutions are sources, while alhConfig may be sources
or produced by the rule below.)
The only rule you need is
> $(COMMON_DIR)/%.alhConfig: %.alhsubstitutions
>         @echo "Inflating alhConfig from $< using local rule"
>         @$(RM) $@
>         @echo "$(MSI) -S$< > $(@F) </dev/null"
>         @$(MSI) -I.. $(ALHFLAGS) -S$< </dev/null > $@
which I would re-write as
	$(ECHO) "Inflating alhConfig from $< using local rule"
	$(MSI) -I.. $(ALHFLAGS) -S$< > [email protected]
	$(MV) [email protected] $@
(Why suppress echoing of the command line and then echo manually in a
separate command, just so you don't see the $(ALHFLAGS) parameter? The
"output to .tmp, then mv" pattern is to make parallel make more reliable.)
Also, the include of RULES_ALARMS below
> File:  Makefile:
> TOP=../../..
> include $(TOP)/configure/CONFIG
> ALHS += ntwk_inj.alhConfig
> include $(TOP)/configure/RULES_ALARMS
is automatically done by the base rules.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS base R3.15.5 special CONFIG and RULE files Bruce Hill
RE: EPICS base R3.15.5 special CONFIG and RULE files Luchini, Kristi L.
Prev: Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
Next: Re: EPICS base R3.15.5 special CONFIG and RULE files Bruce Hill
