Subject: Re: EPICS base R3.15.5 special CONFIG and RULE files
To: "Luchini, Kristi" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Fri, 10 Nov 2017 17:53:27 -0800
Hi Kristi,
In addition to Ben's suggestions, for R3.15.5, you'll also need to change $(MSI) to $(MSI_3_15) in your rules.
If that doesn't get it working, send me the path to your build top and I'll look into it further.
Cheers,
- Bruce
On 11/10/2017 04:38 AM, Benjamin Franksen wrote:
[sorry for possible duplicates, forgot to reply to the list]
On 11/09/2017 11:59 PM, Luchini, Kristi L. wrote:
However, my RULES file from R3.14.12, now either generate errors
during the build or it will generate an empty alhConfig which it
installs in to $TOP/alh.
Is there an example of a RULES_<file type> that I can used. Below is
what I am using, which clearly is wrong.
File configure/Makefile
CHECK_RELEASE = YES
TARGETS = $(CONFIG_TARGETS)
CONFIGS += $(subst ../,,$(wildcard $(CONFIG_INSTALLS)))
CFG +=CONFIG_ALARMS RULES_ALARMS
CFG +=CONFIG_PROTOS
include $(TOP)/configure/RULES
File: configure/CONFIG_ALARMS
FILE_TYPE+=ALHS
INSTALL_ALHS = $(INSTALL_LOCATION)/alh
This is no longer needed as there are now a similar definitions in base,
which use ALH, not ALHS. You can keep you won FILE_TYPE, though, since
due to the different name there is no conflict.
File:  configure/RULES_ALARMS    --- similar to R3.14.12   RULES.Db
This is a mistake. RULES.Db is an overly complicated monster. I wish
there was a way to completely disable it.
All you need is the vpaths:
vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(dir $(ALH))
vpath %.alhsubstitutions $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
however, these are not good. I would rather use
vpath %.alhConfig $(USR_VPATH) $(GENERIC_SRC_DIRS) $(COMMON_DIR)
(Presumably alhsubstitutions are sources, while alhConfig may be sources
or produced by the rule below.)
The only rule you need is
$(COMMON_DIR)/%.alhConfig: %.alhsubstitutions
         @echo "Inflating alhConfig from $< using local rule"
         @$(RM) $@
         @echo "$(MSI) -S$< > $(@F) </dev/null"
         @$(MSI) -I.. $(ALHFLAGS) -S$< </dev/null > $@
which I would re-write as
	$(ECHO) "Inflating alhConfig from $< using local rule"
	$(MSI) -I.. $(ALHFLAGS) -S$< > [email protected]
	$(MV) [email protected] $@
(Why suppress echoing of the command line and then echo manually in a
separate command, just so you don't see the $(ALHFLAGS) parameter? The
"output to .tmp, then mv" pattern is to make parallel make more reliable.)
Also, the include of RULES_ALARMS below
File:  Makefile:
TOP=../../..
include $(TOP)/configure/CONFIG
ALHS += ntwk_inj.alhConfig
include $(TOP)/configure/RULES_ALARMS
is automatically done by the base rules.
Cheers
Ben
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
RE: EPICS base R3.15.5 special CONFIG and RULE files Luchini, Kristi L.
Re: EPICS base R3.15.5 special CONFIG and RULE files Benjamin Franksen
Prev: Re: EPICS base R3.15.5 special CONFIG and RULE files Benjamin Franksen
Next: EPICS communication paradigm renato sanhueza
Next: Re: EPICS base R3.15.5 special CONFIG and RULE files Andrew Johnson
