1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 20 Nov 2017 18:57:36 +0000
These are now all fixed and pushed to master branch on Github.
Sent: Monday, November 20, 2017 8:50 AM
To: Jörn Dreyer; [email protected]
Subject: Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
Hi Jörn,
Thanks for finding that.  I just did a search of all the Makefiles in areaDetector, looking for lines with the string USR_INCLUDES and without the string -I.  There are actually a number of errors like the one you found.  I will fix these today.
corvette:~/devel/areaDetector>find . -name Makefile -exec grep -H USR_INCLUDES {} \; | grep -v "\-I"
./ADPluginEdge/edgeApp/edgeSrc/Makefile:USR_INCLUDES += $(OPENCV_INCLUDE)
./ADAndor/andorApp/src/Makefile:  USR_INCLUDES += $(XML2_INCLUDE)
./ADADSC/adscApp/src/Makefile:# detcon_state.h.  USR_INCLUDES should include the directories containing
./ADURL/urlApp/src/Makefile:    USR_INCLUDES += $(GRAPHICSMAGICK_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/hdf5Src/Makefile:          USR_INCLUDES += $(BLOSC_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(HDF5_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/nexusSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/hdf5_hlSrc/Makefile:        USR_INCLUDES += $(SZIP_INCLUDE)
./ADSupport/supportApp/hdf5_hlSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADSupport/supportApp/bloscSrc/Makefile:        USR_INCLUDES += $(ZLIB_INCLUDE)
./ADCore/ADApp/pluginSrc/Makefile:    USR_INCLUDES += $(GRAPHICSMAGICK_INCLUDE)
./ADCore/ADApp/pluginTests/Makefile:#  USR_INCLUDES += $(HDF5_INCLUDE)
From: [email protected] <[email protected]> on behalf of Jörn Dreyer <[email protected]>
Sent: Monday, November 20, 2017 7:09 AM
To: [email protected]
Subject: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile?
on an Debian based Linux system I had some trouble to compile the areaDetector
module. In CONFIG_SITE.local one can define path variables for various
external components. In contrast to most Linux distributions I know, Debian
installs HDF5 in a sub path under /usr/include/hdf5 depending on the version
of HDF5 that is installed (serial, openmpi, openmpich...) So one has to set up
the correct path in CONFIG_SITE.local. By doing that at using the internal
version of Nexus, I discovered a problem in the Makefile. In this Makefile the
path's for HDF5, SZIP and ZLIB are added to USR_INCLUDES as
USR_INCLUDES += $(HDF5_INCLUDES)
While in all other Makefiles this is included as
USR_INCLUDES += -I$(HDF5_INCLUDES)
The compilation then fails with hdf5.h not found. After adding the -I I was
able to compile areaDetector on this system.
Jörn
Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Jörn Dreyer
Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
Prev: Re: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
Next: Re: issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: synApps_5_8 compilation error Mrinal Kanti Bera
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
