Subject: Re: issue with either camonitor or pcaspy in 3.15?
To: Wang Xiaoqiang <[email protected]>, EPICS tech-talk <[email protected]>
Date: Mon, 20 Nov 2017 13:49:44 -0800
On Mon, Nov 20 2017, Wang Xiaoqiang <[email protected]> wrote:
> The UDF (UnDeFined) alarm and INVALID severity is to indicate the values
> are default values, have not got updated by the driver. This is the same
> behavior as the EPICS database gets initialized on start-up.
> Calling setParamStatus to clear the alarm status is all correct. It is
> then necessary to call driver.updatePVs() to inform ca clients with a
> DBE_ALARM event update. Otherwise this update event will be delayed
> until the next driver.updatePVs() call. And in PCASpy 0.6+, every caput
> triggers a call to driver.updatePVs(). That explains seeing all four
> updates together, in which channel A gives a value update and B,C,D give
> an alarm update.
> To conclude, it is an incompatible change introduced in PCASpy 0.6. I
> created an issue to track this.
> https://github.com/paulscherrerinstitute/pcaspy/issues/48
> In any case, it is best to explicitly call driver.updatePVs() after
> calling setParam, setParamStatus, setParamEnums, setParamInfo. I will
> add this the docs.
Thanks, Xiaoqiang.  This is all very useful info, and adding it to the
documentation would be great.  I'll add updatePVs() to my code where
needed.
jamie.
Attachment: signature.asc
Description: PGP signature
issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
Re: issue with either camonitor or pcaspy in 3.15? Jameson Graef Rollins
Prev: RE: Possible bug in areaDetector/ADSupport/supportApp/nexusSrc/Makefile? Mark Rivers
Next: synApps_5_8 compilation error Mrinal Kanti Bera
Prev: Re: issue with either camonitor or pcaspy in 3.15? Wang Xiaoqiang
Next: Anyone else using Bira Ethernet Power Supply Controllers? Dunning, Michael
