1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on windows
To: Vishnu Patel <[email protected]>, techtalk <[email protected]>
Date: Thu, 4 Jan 2018 04:49:29 +0000
Hi Vishnu,
How did you define EPICS_BASE in seq-2.2.5/configure/RELEASE?  It looks like you may have used a relative path, because your gcc command has this:
-I../../../../../base-3.16.1/include/compiler/gcc
You should use an absolute path to EPICS_BASE.
Note that not much testing is done on cygwin any more.  I would suggest that you consider using the Visual Studio Community Edition which is free, and which is well tested.
From: [email protected] <[email protected]> on behalf of Vishnu Patel <[email protected]>
Sent: Wednesday, January 3, 2018 10:24 PM
To: techtalk
Subject: EPICS on windows
   I want to use EPICS on Windows 7 -64bit.
I installed Cygwin, the epics base-3.16.1 is compiled with Cygwin.
Next i tried to compile sequencer, seq2.2.5, but i am not able to compile it. It gives an error.
user3@user3-PC /cygdrive/c/epics/modules/seq-2.2.5
$ make
make -C ./configure install
make[1]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/configure'
make -C O.cygwin-x86_64 -f ../Makefile TOP=../.. \
    T_A=cygwin-x86_64 install
make[2]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/configure/O.cygwin-x86_64'
perl -CSD /cygdrive/c/epics/base-3.16.1/bin/cygwin-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/configure/O.cygwin-x86_64'
make[1]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/configure'
make -C ./src install
make[1]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src'
make -C ./pv install
make[2]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv'
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv/O.cygwin-x86_64'
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS            -DUNIX  -DCYGWIN32     -O3 -g   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -I../../../../../base-3.16.1/include/compiler/gcc -I../../../../../base-3.16.1/include/os/cygwin32 -I../../../../../base-3.16.1/include         -MM -MF pv.d -MT pv.obj ../pv.c
../pv.c:5:10: fatal error: cadef.h: No such file or directory
 #include "cadef.h"
compilation terminated.
gcc  -D_POSIX_THREADS -D_POSIX_TIMERS            -DUNIX  -DCYGWIN32     -O3 -g   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -I../../../../../base-3.16.1/include/compiler/gcc -I../../../../../base-3.16.1/include/os/cygwin32 -I../../../../../base-3.16.1/include        -o pv.obj -c ../pv.c
 #include "cadef.h"
make[3]: *** [../../../../../base-3.16.1/configure/RULES_BUILD:231: pv.obj] Error 1
make[3]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv/O.cygwin-x86_64'
make[2]: *** [../../../../base-3.16.1/configure/RULES_ARCHS:58: install.cygwin-x86_64] Error 2
make[2]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv'
make[1]: *** [../../../base-3.16.1/configure/RULES_DIRS:84: pv.install] Error 2
make[1]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src'
make: *** [../../base-3.16.1/configure/RULES_DIRS:84: src.install] Error 2
Thanks
Vishnu
Re: EPICS on windows Vishnu Patel
Prev: EPICS on windows Vishnu Patel
Next: void return value in RPC renato sanhueza
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS on windows Vishnu Patel
ANJ, 21 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
