Thanks. I am using cygwin because i would like to test s7nodave on windows for Siemens S7 communication. s7nodave using nodave library, which is coded for linux, I am not able to compile on Windows native compiler. I succeed to compile base3.14.12.7 with asyn3.24 in cygwin . Thanks Dear All If any one using s7nodave on cygwin for siemens PLC please help me. I could compile s7nodave on cygwin, With application for PLC it get compile without any error. But while running application getting dll error, $ ../../bin/cygwin-x86/firsPLC.exe st.cmd C:/cygwin/epics/Devlop/firstPLC/bin/cygwin-x86/firsPLC.exe: error while loading shared libraries: s7nodave.dll: cannot open shared object file: No such file or directory Or someone have compiled s7nodave on native windows compiler> Thanks Vishnu From: Mark Rivers <[email protected]> Sent: Thu, 04 Jan 2018 10:19:33 To: Vishnu Patel <[email protected]>, techtalk <[email protected]> Subject: Re: EPICS on windows Hi Vishnu, How did you define EPICS_BASE in seq-2.2.5/configure/RELEASE? It looks like you may have used a relative path, because your gcc command has this: -I../../../../../base-3.16.1/include/compiler/gcc You should use an absolute path to EPICS_BASE. Note that not much testing is done on cygwin any more. I would suggest that you consider using the Visual Studio Community Edition which is free, and which is well tested. Mark ________________________________ From: [email protected] <[email protected]> on behalf of Vishnu Patel <[email protected]> Sent: Wednesday, January 3, 2018 10:24 PM To: techtalk Subject: EPICS on windows Hi, I want to use EPICS on Windows 7 -64bit. I installed Cygwin, the epics base-3.16.1 is compiled with Cygwin. Next i tried to compile sequencer, seq2.2.5, but i am not able to compile it. It gives an error. -------------------------------------------- user3@user3-PC /cygdrive/c/epics/modules/seq-2.2.5 $ make make -C ./configure install make[1]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/configure' make -C O.cygwin-x86_64 -f ../Makefile TOP=../.. \ T_A=cygwin-x86_64 install make[2]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/configure/O.cygwin-x86_64' perl -CSD /cygdrive/c/epics/base-3.16.1/bin/cygwin-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/configure/O.cygwin-x86_64' make[1]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/configure' make -C ./src install make[1]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src' make -C ./pv install make[2]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv' make -C O.cygwin-x86_64 -f ../Makefile TOP=../../.. \ T_A=cygwin-x86_64 install make[3]: Entering directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv/O.cygwin-x86_64' gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -g -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -I../../../../../base-3.16.1/include/compiler/gcc -I../../../../../base-3.16.1/include/os/cygwin32 -I../../../../../base-3.16.1/include -MM -MF pv.d -MT pv.obj ../pv.c ../pv.c:5:10: fatal error: cadef.h: No such file or directory #include "cadef.h" ^~~~~~~~~ compilation terminated. gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -g -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -I../../../../../base-3.16.1/include/compiler/gcc -I../../../../../base-3.16.1/include/os/cygwin32 -I../../../../../base-3.16.1/include -o pv.obj -c ../pv.c ../pv.c:5:10: fatal error: cadef.h: No such file or directory #include "cadef.h" ^~~~~~~~~ compilation terminated. make[3]: *** [../../../../../base-3.16.1/configure/RULES_BUILD:231: pv.obj] Error 1 make[3]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv/O.cygwin-x86_64' make[2]: *** [../../../../base-3.16.1/configure/RULES_ARCHS:58: install.cygwin-x86_64] Error 2 make[2]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src/pv' make[1]: *** [../../../base-3.16.1/configure/RULES_DIRS:84: pv.install] Error 2 make[1]: Leaving directory '/cygdrive/c/epics/modules/seq-2.2.5/src' make: *** [../../base-3.16.1/configure/RULES_DIRS:84: src.install] Error 2 user3@user3-PC /cygdrive/c/epics/modules/seq-2.2.5 ---------------------------- Thanks Vishnu
ANJ, 21 Jan 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
