Hi Ben,
With the fresh installation of R3.15.5 and R3.16.1, it works.
It doesn't work with my environment. And I've tested with the same
base version with the following modifications:
* BASE patch files
* CONFIG_SITE
* CONFIG_SITE_ENV
My suspicious stays in INSTALL_LOCATION in CONFIG_SITE. It may be
some funny permission issues.
I will investigate them more later and thank you, Ben. I really
appreciate your help.
Best,
Han
On 01/09/2018 08:35 PM, Benjamin Franksen wrote:
On 01/09/2018 03:59 PM, Jeong Han Lee wrote:
* Could you see $(INSTALL_LOCATION)/abc directory after make?
* Could you see two files in that abc directory?
* Could you delete $(INSTALL_LOCATION)/abc directory with make distclean?
Yes to all three.
If so, I will test them again with "fresh" installation of each bases
and sorry about it.
My pleasure.
Cheers
Ben
On 01/09/2018 02:05 PM, Benjamin Franksen wrote:
On 01/09/2018 10:58 AM, Jeong Han Lee wrote:
I've followed old tech-talk at
https://epics.anl.gov/tech-talk/2016/msg00866.php in order to use User
Created File Types, by the suggestion of Ralph.
It works well with EPICS BASE 3.16.1, but it doesn't work with BASE
3.15.5, even if 3.15.5 documentation contains this feature. I looked
some of BASE configuration files (especially FILE_TYPE)
I have the example and dummy repository for this evaluation as
follows:
https://github.com/jeonghanlee/epics-abc
Could you help me to figure out how to resolve them with EPICS
3.15.5?
I have tried your example and it works for me with the HEAD of 3.15
branch.
- Example for User Created File Types in the build system Jeong Han Lee
- Re: Example for User Created File Types in the build system Benjamin Franksen
- Re: Example for User Created File Types in the build system Jeong Han Lee
EPICS V4.7.0 C++ Bundle now available Andrew Johnson
<2018>
asynUInt32DigitalClient constructor Davide Marcato
<2018>
