1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Example for User Created File Types in the build system
Date: Tue, 10 May 2016 23:48:32 +0000
Hi Andrew,
 Thanks for the assist. That was the issue.
 I still seem to need to add an uninstall rule like so for the "make clean"; but for my purposes this is just fine.
This is where I landed.
$ cat configure/CONFIG_ABC
FILE_TYPE += ABC
INSTALL_ABC = $(INSTALL_LOCATION)/abc
$ cat configure/Makefile
CFG += CONFIG_ABC
clean::
     $(RMDIR) $(INSTALL_LOCATION)/abc
Murali
Example for User Created File Types in the build system Shankar, Murali
Prev: measComp R1-3 released Mark Rivers
Next: Build edm failed on Centos 7 yeeon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Example for User Created File Types in the build system Andrew Johnson
Next: measComp R1-3 released Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
