Subject: |
Re: Example for User Created File Types in the build system |
Andrew Johnson <[email protected]> |
To: |
Date: |
Tue, 10 May 2016 16:50:26 -0500 |
Hi Murali,
On 05/10/2016 04:22 PM, Shankar, Murali wrote:
> 1) When I run make for the first time, only the cfg folder shows up. I
> expected the "abc" folder to show up but it didn't.
> 2) If I run make again, the abc folder does indeed show up and it does
> have the "test.abc".
If your CONFIG_ABC file and the CFG += CONFIG_ABC setting are in a
source directory and Makefile that gets built first, they would be in
place when the second Makefile is run that sets ABC. I think the
original idea was to use your <top>/configure directory for installing
the CONFIG_* files from, it has its own Makefile which is suitable for
doing that installation.
> 3) And when I run "make clean distclean", the abc folder stays behind.
The uninstall rule may be reliant on the CONFIG_ABC file being in your
configure directory as I mentioned above. I think doing that should fix
your issues, it seems to work properly for me.
HTH,
- Andrew
- Example for User Created File Types in the build system Shankar, Murali
RE: EPICS support with NI-Daqmx freddie.akeroyd
<2016>
2025
2026
Re: Example for User Created File Types in the build system Shankar, Murali
<2016>
2025
2026
