1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS support with NI-Daqmx
To: <[email protected]>, <[email protected]>
Date: Tue, 10 May 2016 22:37:18 +0000
Or using OPC could be another option
http://digital.ni.com/public.nsf/allkb/DBEEA58DDA77C14E862570E700726ECB
http://www-csr.bessy.de/control/SoftDist/OPCsupport/
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 10 May 2016 17:22
To: [email protected]; [email protected]
Hi Ana,
A while back I thought I was about to need some DAQmx support and so I built the code at http://sourceforge.net/p/epics/svn/HEAD/tree/applications/trunk/DAQmxBase/  but I didn't get round to using it properly as the need went away. The code there should build OK on Linux, if you wanted to run it on windows then it would require a few modifications which I put at https://github.com/ISISComputingGroup/EPICS-DAQmxBase  (on windows the code can build with either DAQmx or DAQmxBase).
Another option might be to use NI Network Shared Variables – it looks like NI-DAQmx includes an I/O server that can publish NI-DAQmx global virtual channels as these, and then you could connect to them from an EPICS IOC running on either Linux or Windows using the NetShrVar module http://epics.isis.stfc.ac.uk/doxygen/NetShrVar/   I don’t believe LabVIEW is required to do this, just NI-MAX  http://zone.ni.com/reference/en-XX/help/370466W-01/mxcncpts/ioserver/
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Ana Malagon
Sent: 10 May 2016 01:49
Subject: EPICS support with NI-Daqmx
I'm trying to integrate a National Instruments compact daq (9184), and thought I'd ask if anybody has recently worked on EPICS support for this device, or other devices that also need the National Instruments NI-Daqmx library? I was looking through the tech-talk archives and found one lead:
http://www.aps.anl.gov/epics/tech-talk/2013/msg01052.php
but looks like this project doesn't work with recent versions of base and asyn. Just wanted to see if anyone has worked on this sort of problem recently so as not to reinvent the wheel - thanks!
Best,
Ana
Re: EPICS support with NI-Daqmx Ana Malagon
RE: EPICS support with NI-Daqmx freddie.akeroyd
Prev: Re: Example for User Created File Types in the build system Andrew Johnson
Next: measComp R1-3 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS support with NI-Daqmx freddie.akeroyd
Next: Re: EPICS support with NI-Daqmx Ana Malagon
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
