Hi, I was trying to build the EPICS-DAQmxBaseApp with cygwin-x86_64 on windows8 and I got the error as: /cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master $ make configure/RELEASE:2: ../../../configure/MASTER_RELEASE: No such file or directory configure/RELEASE:11: ../../../ISIS_CONFIG: No such file or directory make: *** No rule to make target '../../../ISIS_CONFIG'. Stop. I made changes to the configure file i.e commented the MASTER_Release..... and also I tried to build the app with NIDAQmx and commented out the NIDAQmxBase Part in C:\epics\Applications\nidaqmx\EPICS-DAQmxBase-master\DAQmxBaseApp\src\makefile but still got the below error: $ make make -C ./configure install make[1]: Entering directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/configure' make -C O.cygwin-x86_64 -f ../Makefile TOP=../.. T_A=cygwin-x86_64 install make[2]: Entering directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/configure/O.cygwin-x86_64' perl /cygdrive/c/epics/base-3.14.12.4/bin/cygwin-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/configure/O.cygwin-x86_64' make[1]: Leaving directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/configure' make -C ./DAQmxBaseApp install make[1]: Entering directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp' make -C ./src install make[2]: Entering directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp/src' make -C O.cygwin-x86_64 -f ../Makefile TOP=../../.. T_A=cygwin-x86_64 install make[3]: Entering directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp/src/O.cygwin-x86_64' gcc -c -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -DDODAQMXFULL=1 -m64 -D_DLL -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/cygwin32 -I../../../include -I/cygdrive/c/epics/base-3.14.12.4/modules/soft/asyn4-25//include -I/cygdrive/c/epics/base-3.14.12.4/include/os/cygwin32 -I/cygdrive/c/epics/base-3.14.12.4/include -I/cygdrive/c/Program\ Files\ \(x86\)/National\ Instruments/Shared/ExternalCompilerSupport/C/include drvDaqMx.c In file included from drvDaqMx.c:65:0: /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:85:2: error: unknown type name ‘__int64’ typedef __int64 int64; ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:93:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘uInt64’ typedef unsigned __int64 uInt64; ^ In file included from drvDaqMx.c:65:0: /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2546:145: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgSampClkTiming (TaskHandle taskHandle, const char source[], float64 rate, int32 activeEdge, int32 sampleMode, uInt64 sampsPerChan); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2548:92: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgHandshakingTiming (TaskHandle taskHandle, int32 sampleMode, uInt64 sampsPerChan); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2550:102: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgBurstHandshakingTimingImportClock(TaskHandle taskHandle, int32 sampleMode, uInt64 sampsPerChan, float64 sampleClkRate, const char sampleClkSrc[], int32 sampleClkActiveEdge, int32 pauseWhen, int32 readyEventActiveLevel); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2552:102: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgBurstHandshakingTimingExportClock(TaskHandle taskHandle, int32 sampleMode, uInt64 sampsPerChan, float64 sampleClkRate, const char sampleClkOutpTerm[], int32 sampleClkPulsePolarity, int32 pauseWhen, int32 readyEventActiveLevel); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2553:151: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgChangeDetectionTiming (TaskHandle taskHandle, const char risingEdgeChan[], const char fallingEdgeChan[], int32 sampleMode, uInt64 sampsPerChan); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2555:92: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgImplicitTiming (TaskHandle taskHandle, int32 sampleMode, uInt64 sampsPerChan); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:2557:145: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxCfgPipelinedSampClkTiming (TaskHandle taskHandle, const char source[], float64 rate, int32 activeEdge, int32 sampleMode, uInt64 sampsPerChan); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5829:66: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetLoggingSampsPerFile(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5830:66: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxSetLoggingSampsPerFile(TaskHandle taskHandle, uInt64 data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5837:75: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetLoggingFilePreallocationSize(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5838:75: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxSetLoggingFilePreallocationSize(TaskHandle taskHandle, uInt64 data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5841:62: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetReadCurrReadPos(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:5845:75: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetReadTotalSampPerChanAcquired(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:6080:67: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetSampQuantSampPerChan(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:6081:67: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxSetSampQuantSampPerChan(TaskHandle taskHandle, uInt64 data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:6892:64: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetWriteCurrWritePos(TaskHandle taskHandle, uInt64 *data); ^ /cygdrive/c/Program Files (x86)/National Instruments/Shared/ExternalCompilerSupport/C/include/NIDAQmx.h:6920:77: error: unknown type name ‘uInt64’ int32 __CFUNC DAQmxGetWriteTotalSampPerChanGenerated(TaskHandle taskHandle, uInt64 *data); ^ drvDaqMx.c:240:2: error: ‘write’ redeclared as different kind of symbol write, ^ In file included from /usr/include/sys/types.h:20:0, from drvDaqMx.c:25: /usr/include/sys/unistd.h:197:25: note: previous declaration of ‘write’ was here _READ_WRITE_RETURN_TYPE _EXFUN(write, (int __fd, const void *__buf, size_t __nbyte )); ^ drvDaqMx.c:2021:22: error: static declaration of ‘getAsynPort’ follows non-static declaration static daqMxBasePvt *getAsynPort(char *portName ) ^ drvDaqMx.c:495:15: note: previous declaration of ‘getAsynPort’ was here daqMxBasePvt *getAsynPort( char *portName ); ^ drvDaqMx.c:2748:12: error: static declaration of ‘DAQmxBaseConfig’ follows non-static declaration static int DAQmxBaseConfig(char *portName, char * deviceName, int Channelnr, char * sacqType, char* options) ^ drvDaqMx.c:499:5: note: previous declaration of ‘DAQmxBaseConfig’ was here int DAQmxBaseConfig(char *portName, char * deviceName, int Channelnr, char* sacqType, char* options); ^ drvDaqMx.c:3168:13: error: static declaration of ‘daqThread’ follows non-static declaration static void daqThread(void *param) ^ drvDaqMx.c:488:6: note: previous declaration of ‘daqThread’ was here void daqThread(void *param); ^ drvDaqMx.c: In function ‘daqThread’: drvDaqMx.c:3529:6: warning: implicit declaration of function ‘DAQmxCfgImplicitTiming’ [-Wimplicit-function-declaration] if (DAQmxFailed(DAQmxBaseCfgImplicitTiming(pPvt->taskHandle, ^ drvDaqMx.c:3558:9: warning: implicit declaration of function ‘DAQmxCfgSampClkTiming’ [-Wimplicit-function-declaration] if( DAQmxFailed( DAQmxBaseCfgSampClkTiming( pPvt->taskHandle, ^ drvDaqMx.c:3598:5: warning: zero-length gnu_printf format string [-Wformat-zero-length] asynPrint(pPvt->pasynUser,ASYN_TRACE_ERROR, ^ drvDaqMx.c: At top level: drvDaqMx.c:3168:13: warning: ‘daqThread’ defined but not used [-Wunused-function] static void daqThread(void *param) ^ /cygdrive/c/epics/base-3.14.12.4/configure/RULES_BUILD:199: recipe for target 'drvDaqMx.o' failed make[3]: *** [drvDaqMx.o] Error 1 make[3]: Leaving directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp/src/O.cygwin-x86_64' /cygdrive/c/epics/base-3.14.12.4/configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86_64' failed make[2]: *** [install.cygwin-x86_64] Error 2 make[2]: Leaving directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp/src' /cygdrive/c/epics/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory '/cygdrive/c/epics/Applications/nidaqmx/EPICS-DAQmxBase-master/DAQmxBaseApp' /cygdrive/c/epics/base-3.14.12.4/configure/RULES_DIRS:70: recipe for target 'DAQmxBaseApp.install' failed make: *** [DAQmxBaseApp.install] Error 2... Kindly help and suggest the changes as I could not resolve the error. Thanks Arnab
| ANJ, 24 Jan 2018 |
· Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
