1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request]
To: EPICS Tech Talk <[email protected]>
Date: Tue, 16 Jan 2018 19:13:23 +0100
On Tue, Jan 16, 2018 at 5:06 PM, J. Lewis Muir <[email protected]> wrote:
On 01/15, Ralph Lange wrote:
> Note, though, that Channel Access never claimed to be hardened. Even after
> fixing this behavior, an attacker on the local network will be able to
> cause all sorts of havoc by sending malformed network packages to CA
> servers and clients.
> Channel Access is not intended for use in a hostile environment.
I wouldn't call a port scan hostile.
True. Let me rephrase:
Channel Access is not intended for use in an environment where clients intentionally send malformed packages.
Cheers,
~Ralph
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Benjamin Franksen
Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Shuei YAMADA
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Ralph Lange
Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] J. Lewis Muir
Prev: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] J. Lewis Muir
Next: EPICS-DAQmx App Build Issues on cygwin-x86_64 Arnab Dasgupta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: Re: Port scan with nmap causes infinite loop in casDGClient::processDG() [Re: CA gatway runs away when zero length PV name in UDP search request] Benjamin Franksen
ANJ, 23 Jan 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
