1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: IOC crash
To: Hinko Kocevar <[email protected]>
Date: Thu, 18 Jan 2018 13:29:14 -0800
Hinko,
If you can get a core dump, please include all threads (gdb command "thread apply all backtrace").
I remember that I was suspicious of a race with another thread.
On 01/18/2018 10:17 AM, Hinko Kocevar wrote:
> Hi Mark,
> I'll try to find the core file. Thanks for the tip.
> /Hinko
> On Thu, 18 Jan 2018 at 13:31, Mark Rivers <[email protected] <mailto:[email protected]>> wrote:
>     Hi Hinko,
>     Since it generated a core file you should be able to do some more debugging with gdb.  For example what are the values of "size" and pMsg->postsize in caserverio.c?  You might be able to figure out what PV this is.
>     Mark
>     ________________________________
>     From: [email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>> on behalf of Hinko Kocevar <[email protected] <mailto:[email protected]>>
>     Sent: Thursday, January 18, 2018 4:55 AM
>     To: [email protected] <mailto:[email protected]>
>     Subject: IOC crash
>     Dear EPICS users,
>     here is the error I got from the IOC running EPICS base 3.15.4:
>     A call to 'assert(size <= ntohs ( pMsg->m_postsize ))'
>         by thread 'CAS-event' failed in ../../../src/ioc/rsrv/caserverio.c line 357.
>     Dumping a stack trace of thread 'CAS-event':
>     [    0x7f4f3abf070b]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(epicsStackTrace+0x4b)
>     [    0x7f4f3abe9e1a]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(epicsAssert+0x3a)
>     [    0x7f4f3b0db512]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(cas_commit_msg+0x92)
>     [    0x7f4f3b0df468]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(read_reply+0x1d8)
>     [    0x7f4f3b0b82f4]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libdbCore.so.3.15.4(event_task+0x1d4)
>     [    0x7f4f3abeaf5c]:
>     /data/shi/R3.15.4/base/lib/linux-x86_64/libCom.so.3.15.4(start_routine+0xdc)
>     [    0x7f4f38ca8e25]: /lib64/libpthread.so.0(start_thread+0xc5)
>     [    0x7f4f3931f34d]: /lib64/libc.so.6(clone+0x6d)
>     EPICS Release EPICS R3.15.4 $$Date$$.
>     Local time is 2018-01-18 11:27:33.597318519 CET
>     Please E-mail this message to the author or to [email protected] <mailto:[email protected]>
>     Calling epicsThreadSuspendSelf()
>     Thread CAS-event (0x7f4ef804c510) suspended
>     CAS: request from 127.0.0.1:48578 <http://127.0.0.1:48578> => bad resource ID
>     CAS: Request from 127.0.0.1:48578 <http://127.0.0.1:48578> => cmmd=2 cid=0x1ce3 type=34 count=1
>     postsize=0
>     CAS: Request from 127.0.0.1:48578 <http://127.0.0.1:48578> =>   available=0x1058 N=0 paddr=0x7f4ec000c5e8
>     CAS: forcing disconnect from 127.0.0.1:48578 <http://127.0.0.1:48578>
>     Segmentation fault (core dumped)
>     Thanks,
>     Hinko
> .. the more I see the less I believe.., AE AoR
Re: IOC crash Hinko Kocevar
Re: IOC crash Mark Rivers
Prev: Re: IOC crash Michael Davidsaver
Next: Re: Forcing make rule in IOC Makefile Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Re: IOC crash Hinko Kocevar
Next: Re: IOC crash Hinko Kocevar
ANJ, 19 Jan 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
