Hi Mark, Till,
Changing the arrays to the correct type and updating my EZCA library to the one on Github fixed the problem.
Thanks for your help, guys.
Pete.
Sent: Saturday, January 20, 2018 9:35 PM
To: Till Straumann
Cc: Siddons, David; [email protected]
Subject: Re: ezca
Hi Till,
The version on Github had your enhancements merged into it in 2011. There have been several fixes to it since then.
Sent from my iPhone
> On Jan 20, 2018, at 7:35 PM, Till Straumann <[email protected]> wrote:
> A long time ago I created a thread-safe fork of ezca for the labCA matlab/scilab CA interface
> (http://www.slac.stanford.edu/~strauman/labca/) This definitely works on 64-bit systems (linux + windows).
> I don't know if we are using it already with 3.15 but we definitely will and I don't anticipate
> serious problems.
> - Till
>> On 01/20/2018 04:22 PM, Mark Rivers wrote:
>> Hi Pete,
>>> I'm having some trouble with EZCA. Does anyone else still use this?
>> Yes, we use it because it is part of the IDL EPICS interface. It is also part of the matlab EPICS interface, which I don't use but I know that others do.
>>> Do we know if there are 64-bit issues with it?
>> I have been using it with 64-bit IDL for many years and have never seen any problems.
>>> Does it work with 3.15.5?
>> Yes. Here is the output of ldd on my IDL shareable library for EPICS.
>> corvette:extensions/lib/linux-x86_64>ldd /usr/local/idl_user/epics/libezcaIDL.so_linux_x86_64
>> linux-vdso.so.1 => (0x00007ffcaa342000)
>> libezca.so => /usr/local/epics/extensions/lib/linux-x86_64/libezca.so (0x00007f077cbd5000)
>> libEzcaScan.so => /usr/local/epics/extensions/lib/linux-x86_64/libEzcaScan.so (0x00007f077c9c9000)
>> libca.so.3.15.5 => /usr/local/epics/base-3.15.5/lib/linux-x86_64/libca.so.3.15.5 (0x00007f077c75f000)
>> libCom.so.3.15.5 => /usr/local/epics/base-3.15.5/lib/linux-x86_64/libCom.so.3.15.5 (0x00007f077c4ec000)
>> libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f077c2b9000)
>> libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f077c073000)
>> librt.so.1 => /lib64/librt.so.1 (0x00007f077be6b000)
>> libdl.so.2 => /lib64/libdl.so.2 (0x00007f077bc66000)
>> libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f077b95e000)
>> libm.so.6 => /lib64/libm.so.6 (0x00007f077b65c000)
>> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f077b445000)
>> libc.so.6 => /lib64/libc.so.6 (0x00007f077b082000)
>> /lib64/ld-linux-x86-64.so.2 (0x000055fd08911000)
>> libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f077ae57000)
>> So it is using the 3.15.5 versions of libCom and libca.
>>> I see wrong values from an ezcaGet of an array of long ints. The caget shell command gets the right values.
>> What version of ezca are you using? The latest (though still over 4 years old) is on Github:
>> https://github.com/epics-extensions/ezca
>> You are referring to the function ezcaGet in the ezca library? So you are calling this from an application you have written?
>> Can you send the source code for that application, and the incorrect output you are getting?
>> Cheers,
>> Mark
>> From: [email protected] <[email protected]> on behalf of Siddons, David <[email protected]>
>> Sent: Saturday, January 20, 2018 3:16 PM
>> To: techtalk [[email protected]]
>> Subject: ezca
>> Hi Tech-talk,
>> I'm having some trouble with EZCA. Does anyone else still use this? Do we know if there are 64-bit issues with it? Does it work with 3.15.5? I see wrong values from an ezcaGet of an array of long ints. The caget shell command gets the right values.
>> Pete.
- ezca Siddons, David
- Re: ezca Mark Rivers
- Re: ezca Till Straumann
Re: Seq-2.2.5 compilation on windows Vishnu Patel
<2018>
EPICS Support for RedPitaya Andraz Pozar
<2018>
