Hello everybody,
I'm wondering if it is possible to change the scan value to a value
below 0.1 second, which is the lowest value explained in the documentation.
If not, there is another way of changing this value below .1 second??
Thank you very much for your answer.
Pilar Gil Jaldo
Seven Solutions | Embedded SW Engineer
2, Periodista Rafael Gómez Montero. Edf. CETIC-UGR, Oficina 13 - Planta
1 18014, Granada - SPAIN
This e-mail and any materials attached hereto, including, without
limitation, all content hereof and thereof are confidential and
proprietary to Seven Solutions,S.L and/or its affiliates.
Without the prior written consent of Seven Solutions, this content may
not (i) be disclosed to any third party, (ii) be reproduced, modified or
otherwise used by anyone other than
current employees of Seven Solutions or its affiliates. If you are not
the intended recipient or if this message has been received in error,
please immediately notify us via e-mail and delete it.
- Re: PV Scan - Set values J. Lewis Muir
Re: How to work with motor record position counts larger than 2147483648? Torsten Bögershausen
Re: PV Scan - Set values Anton Derbenev
<2018>
<2018>
ANJ, 23 Jan 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
