1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: PV Scan - Set values
To: Pilar Gil Jaldo <[email protected]>
Cc: [email protected]
Date: Tue, 23 Jan 2018 09:59:11 -0600
On 01/23, Pilar Gil Jaldo wrote:
> Hello everybody,
> I'm wondering if it is possible to change the scan value to a value
> below 0.1 second, which is the lowest value explained in the
> documentation.
> If not, there is another way of changing this value below .1 second??
> Thank you very much for your answer.
Hi, Pilar.
You can change it in menuScan.dbd, as others have noted.  However, doing
this makes your IOC different than most and may introduce other issues,
so I would suggest avoiding changing it unless you have a very good
reason to do so.
What are you trying to do?  Maybe if you describe what you're trying
to do, someone can suggest a good approach.  For example, it might be
better to run something at a higher frequency as a Sequencer program or
an Asyn-based program or driver.
Lewis
PV Scan - Set values Pilar Gil Jaldo
Prev: Re: Seq-2.2.5 compilation on windows Benjamin Franksen
Next: Re: Seq-2.2.5 compilation on windows Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: PV Scan - Set values Pilar Gil Jaldo
Next: Re: PV Scan - Set values Anton Derbenev
ANJ, 23 Jan 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
