I was wondering if there is a current recommended method for implementing device support for bidirectional records. That is, records that both write values that are obtained through EPICS to a device and also update
their value to reflect the status of the device when it changes through means outside of EPICS.
On a related note, are there versions of the standard output records (bo, ao, longout, etc.) that have a separate readback field in engineering units?
Thank you for your time,
Patrick
