1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Subject: Re: CalcOut record update to another record
To: Amien WORK <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 25 Jan 2018 12:34:38 +0000
Hi Amien,
I have a few comments and questions.
In "cur" you have this line:
       field(INPB,        "$(dev):coefOffset.PROC CP MS")
I don't think this will work.  You have CP on the PROC field, meaning you want the record to process when the PROC field changes.  However, EPICS does not post monitors on the PROC field according to this document:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon
In coefOffset you have this line:
        field(FLNK,        "$(dev):newcur")
This will process newcur, but not cause it to obtain a new value.  Is this intended?
In calc_offset1 you have this line:
        field(OUT,         "$(dev):newcur")
The will write the new value to newcur, but without processing newcur.  Is this intended?  It means newcur will only process when coefOffset is processed.
You have not shown the "range" record.  Does that have an FLNK to coefOffset?
From: [email protected] <[email protected]> on behalf of Amien WORK <[email protected]>
Sent: Thursday, January 25, 2018 3:25 AM
To: EPICS Tech-Talk
Subject: CalcOut record update to another record
Hi
    record(calcout,        "$(dev):cur")
        field(INPA,        "$(dev):raw_cur.VAL CP MS")
        field(OOPT,        "Every Time")
        field(DOPT,        "Use CALC")
        field(CALC,        "A-B")
        field(FLNK,        "$(dev):rangeunit")
    record(ao,             "$(dev):newcur")
        field(DTYP,        "Soft Channel")
    record(sel,            "$(dev):coefOffset")
        field(SELM,        "Specified")
        field(NVL,         "$(dev):range")
        field(INPB,        "$(dev):calc_offset1.VAL")
        field(INPC,        "$(dev):calc_offset2.VAL")
        field(INPD,        "$(dev):calc_offset3.VAL")
        field(INPE,        "$(dev):calc_offset4.VAL")
        field(INPF,        "$(dev):calc_offset5.VAL")
        field(INPG,        "$(dev):calc_offset6.VAL")
        field(INPH,        "$(dev):calc_offset7.VAL")
        field(INPI,        "$(dev):calc_offset8.VAL")
    ## below is offset1 of 8 possible offsets I need to save
    record(bo,            "$(dev):store_offset1")
        field(PINI,        "YES")
        field(VAL,        "0")
        field(FLNK,        "$(dev):calc_offset1" )
    record(bo,            "$(dev):clear_offset1")
        field(VAL,        "0")
        field(OUT,        "$(dev):store_offset1")
        field(FLNK,        "$(dev):store_offset1")
    record(calcout,        "$(dev):calc_offset1")
        field(PINI,        "YES")
        field(INPA,        "$(dev):raw_cur.VAL")   # rawval
        field(INPB,        "$(dev):store_offset1")
        field(CALC,        "B=1?A:0*A")
My problem is that I see the calculated values like $(dev):calc_offset1 correctly, but the $(dev):newcur shows 0.
I want to have a 'current' offset (newcur)  that changes depending on what the current 'range' is (user can select Range 1 to 8)
Amien
CalcOut record update to another record Amien WORK
Prev: Problems with scaler record on epics archiver Gabriel de Souza Fedel
Next: Re: Problems with scaler record on epics archiver Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025
Prev: CalcOut record update to another record Amien WORK
Next: Problems with scaler record on epics archiver Gabriel de Souza Fedel
ANJ, 25 Jan 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
