1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvPut error message by Sequencer
To: Simon Reiter <[email protected]>, <[email protected]>
Date: Tue, 30 Jan 2018 16:15:13 +0100
On 01/30/2018 03:31 PM, Simon Reiter wrote:
> after updating from EPICS 3.14.12.6 to 3.16.1 I receive the following
> message.
> A PV is set by the sequencer (2.2.4). It is actually done, but every
> time, the sequencer set the PV, I get this message.
>     sevr=minor ca_array_put(typeToCA(type), count, var->chid, value):
> Channel write request failed
> int pv_variable;
> assign pv_variable to "{IOC}:timeout:S";
> pv_variable = value;
> pvPut(pv_variable);
> The connected PV is binary output.
From looking at the CA sources it seems that this is ECA_PUTFAIL error
code, which is used as the default (catch-all) error code in
src/ca/client/oldChannelNotify.cpp e.g. line 525:
    catch ( ... )
        caStatus = ECA_PUTFAIL;
So we know that /something/ fails and it is not any of the expected
exceptions (cacChannel::badString, ... std::bad_alloc). You could insert
debug statements in the catch-all clause to print more information about
the exception.
Does a caput from the command line work also result in an error message?
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: pvPut error message by Sequencer Ralph Lange
Re: pvPut error message by Sequencer Simon Reiter
Scanning on event number fails with EPICS 3.16 Simon Reiter
Prev: Re: Scanning on event number fails with EPICS 3.16 Ralph Lange
Next: Re: pvPut error message by Sequencer Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: pvPut error message by Sequencer Simon Reiter
ANJ, 30 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
