1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer seem to skip states with EPICS 3.16.1
To: [email protected]
Date: Tue, 30 Jan 2018 22:43:58 +0100
> What record type do you use to represent your state?
> In the CA server, updates for strings are handled using a reference (pointer) in the queue, while numerical type updates put their value in the queue.
> If your record has a string value, two fast subsequent writes to it may actually lead to the first string never being sent, if it gets overwritten while the event with the pointer to it is still in the outgoing queue. In that case, it might be better to use an mbbi or mbbo (enum type) record, because an enum's natural type is numerical, while it still has nice string representations for its states.
The state machine is already built up with mbbi and mbbo records.
Here is an excerpt  of the state machine. Maybe this helps to discover some misbehavior:
> state S_READY {
>     entry {
>         // some logging
>     when(pv_state_request == STATE_RUNNING) {
>     } state S_STARTING
> state S_STARTING {
>     entry {
>         // some logging
>     when(pv_allow_running) { // this pv is in most cases already 1.
>     } state S_RUNNING
> state S_RUNNING {
>     entry {
>         // some logging
S_ = states
STATE_ = enum values
BTW: In order to use logging, this state machine is implemented in C++.
Cheers, Simon
Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Next: Fwd: JSPS Postdoctral Fellowships for Research in Japan Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
