1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: procServ under systemd service
To: Hinko Kocevar <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 6 Feb 2018 14:41:50 +0000
Hi
If I understood your aims correctly:
- you can let systemd to kill also procServ (ref. to: man systemd.kill) via systemd service configuration,
- you can send control character, e.g.: ^Q, to procServ to quit itself, via shell script defined in 'ExecStop='  of the service,
then, in both cases, systemd may restart your service , if configured so.
The second option is based on procServControl (DLS Controls).
With ASCII control codes,
https://en.wikipedia.org/wiki/C0_and_C1_control_codes
, one can send any of procServ control commands to its management port, e.g:
# send ^Q to procServ
/bin/sh -c "/bin/echo -e '\x11' | /bin/nc -w 1 localhost 20000"
Cheers,
Tomas
Od: [email protected] [[email protected]] za uživatele Hinko Kocevar [[email protected]]
Odesláno: 6. února 2018 15:08
Komu: [email protected]
Předmět: procServ under systemd service
I want to run procServ 2.7.0 that startd the IOC with systemd. I have
the .service file and things seems to behave quite nice so far.
What I need now is that after procServ child dies/exits control is
returned all the way to systemd service because I want to execute a
command after IOC has stopped.
Is there a way to tell procServ to exit after child has finished?
Systemd service would of course start procServ back up.
Hinko
Re: procServ under systemd service Hinko Kocevar
Prev: procServ under systemd service Hinko Kocevar
Next: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Johannes Spinneken (EGI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: procServ under systemd service Hinko Kocevar
ANJ, 07 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
