1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ under systemd service
To: Mazanec Tomáš <[email protected]>
Date: Wed, 7 Feb 2018 10:04:12 +0100
Hi Tomas,
thanks for the suggestions.
Actually I was looking for a way for procServ to exit once the client
has died. I know this sounds silly since procServ is supposed to live
forever and restart the client if it dies.. maybe I need to rethink my
strategy about this.
Cheers,
Hinko
On Tue, Feb 6, 2018 at 3:41 PM, Mazanec Tomáš
<[email protected]> wrote:
> Hi
> If I understood your aims correctly:
> - you can let systemd to kill also procServ (ref. to: man systemd.kill) via systemd service configuration,
> - you can send control character, e.g.: ^Q, to procServ to quit itself, via shell script defined in 'ExecStop='  of the service,
> then, in both cases, systemd may restart your service , if configured so.
> The second option is based on procServControl (DLS Controls).
> With ASCII control codes,
> https://en.wikipedia.org/wiki/C0_and_C1_control_codes
> , one can send any of procServ control commands to its management port, e.g:
> # send ^Q to procServ
> /bin/sh -c "/bin/echo -e '\x11' | /bin/nc -w 1 localhost 20000"
> Cheers,
> Tomas
> Od: [email protected] [[email protected]] za uživatele Hinko Kocevar [[email protected]]
> Odesláno: 6. února 2018 15:08
> Komu: [email protected]
> Předmět: procServ under systemd service
> Hi,
> I want to run procServ 2.7.0 that startd the IOC with systemd. I have
> the .service file and things seems to behave quite nice so far.
> What I need now is that after procServ child dies/exits control is
> returned all the way to systemd service because I want to execute a
> command after IOC has stopped.
> Is there a way to tell procServ to exit after child has finished?
> Systemd service would of course start procServ back up.
> Thanks,
> Hinko
.. the more I see the less I believe.., AE AoR
Re: procServ under systemd service Ralph Lange
procServ under systemd service Hinko Kocevar
RE: procServ under systemd service Mazanec Tomáš
Prev: RE: FLIR Spinnaker SDK: Request for input ulrik.pedersen
Next: RE: EtherCAT newbie question ronaldo.mercado
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: procServ under systemd service Mazanec Tomáš
Next: Re: procServ under systemd service Ralph Lange
ANJ, 07 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
