1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EtherCAT newbie question
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 7 Feb 2018 09:35:35 +0000
Hi Mark,
As Torsten and Jeong Han have already said, the Diamond Ethercat EPICS support is available [1], but it does not support motion.
For some digital I/O and analog I/O we would use kit from our supported set [2].
The master in our setup runs on a Dell R310, using Redhat MRG (real time pre-empt rt kernel).
The minimal ethercat kit would be:  EK1100 coupler, EL1014 (digital input), EL3104 (analogue input), EL2024 (digital output), EL4134 (analogue output).
Best regards,
Ronaldo
[1] https://github.com/dls-controls/ethercat
[2] See https://epics.anl.gov/tech-talk/2015/msg01665.php
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Torsten Bögershausen
Sent: 07 February 2018 05:29
To: Mark Rivers; [email protected]
Subject: Re: EtherCAT newbie question
Hej Mark,
this is what we use for our motion control test/development crates:
# CPU: CX5130
# Configure EL1018 digital input terminal
# Configure EL2808 digital output terminal
# Configure EL5101 incremental encoder terminal, motor 1
# Configure EL5101 incremental encoder terminal, motor 2
# Configure EL9505 Power supply terminal 5V
# Configure EL1252 digital input terminal
# Configure EL7037 stepper drive terminal, motor 1
# Configure EL7037 stepper drive terminal, motor 2
(No analog IO in our motion crates ;-)
No sure if you have access to this page about other terminals for motion:
https://confluence.esss.lu.se/display/MCAG/Motion+Controller
HTH
/Torsten
PS:
As Han Lee pointed out, there are different SW packages:
- Beckhoff TwinCAT
- Linux ("scanner" from DLS and ecat2 from PSI) (but no motion control)
- Linux ECMC from ESS http://icalepcs2017.vrws.de/talks/mocpl05_talk.pdf
And we are happy to help.
On 06/02/18 20:37, Mark Rivers wrote:
> I am interested in trying out EtherCAT with a simple inexpensive setup.  What
> are the minimum parts I need to buy if I want to use the EPICS EtherCAT driver
> to control some digital I/O, analog I/O, and a stepper motor?  I looked at the
> Beckhoff website, but I find it overwhelming.
> Thanks,
> Mark
Re: EtherCAT newbie question Stubbs, Scott A.
RE: EtherCAT newbie question Linda.Pratt
EtherCAT newbie question Mark Rivers
Re: EtherCAT newbie question Torsten Bögershausen
Prev: Re: procServ under systemd service Hinko Kocevar
Next: Re: procServ under systemd service Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EtherCAT newbie question Torsten Bögershausen
Next: Re: EtherCAT newbie question Stubbs, Scott A.
ANJ, 09 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
