1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: EtherCAT newbie question
To: [email protected]
Date: Tue, 6 Feb 2018 22:35:01 +0100
Hi Mark,
The simple inexpensive setup, one needs the EtherCAT Master and the EtherCAT Slave
1) EtherCAT Master : There are three different versions, which ESS is facing currently due to many other reasons. In order to configure the the master, please look at my ugly script repo :
   https://github.com/jeonghanlee/ecat_setup
   I think, you can find
 2) HW list
  * EK1100	EtherCAT Coupler (EtherCAT Terminals EL/ESxxxx)
  * Some modules AI/AO and so on
  * EL9011	Bus end cap
  You need a PC have two Ethernet interfaces.
 3)  EPICS EtherCAT Driver and DB
  3.1) Diamond  https://github.com/dls-controls/ethercat
  3.2) PSI  https://github.com/paulscherrerinstitute/ecat2
3.2*) ESS https://github.com/icshwi/m-epics-ecat2 (old forked version of PSI)
3.2 and 3.2* need the ecat2db files such as https://github.com/icshwi/e3-ecat2db
You can select HW (Slave) list based on ecat2db files if you want to try them.
Well, it is not the perfect condition in terms of many issues for the future. We are trying to find a way in order to minimize risks in the future now.
  HTH,
  Han
P.S. I enclosed the file, which I built for the lab.
On 02/06/2018 08:37 PM, Mark Rivers wrote:
I am interested in trying out EtherCAT with a simple inexpensive setup. What are the minimum parts I need to buy if I want to use the EPICS EtherCAT driver to control some digital I/O, analog I/O, and a stepper motor?  I looked at the Beckhoff website, but I find it overwhelming.
Attachment: IMG_3382.JPG
Description: JPEG image
EtherCAT newbie question Mark Rivers
Prev: RE: Latency between NI LabVIEW RT (cRIO) and EPICS on RT Linux Mark Rivers
Next: Re: EtherCAT newbie question Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: EtherCAT newbie question Mark Rivers
ANJ, 06 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
