1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: AreaDetector repository inconsistent
Date: Wed, 7 Feb 2018 13:14:58 -0600 (CST)
On Wed, 7 Feb 2018, Mark Rivers wrote:
Ø  I like the certainty of using tar files of released versions in most cases, and explicitly deployed git clones in a beamline's local file tree if it's required.
I think “git checkout R3-4” is as certain as getting the R3-4 tar file.
The advantage of the git clone is that you can immediately see if someone has changed a file with “git diff R3-4”.  If you have a tar file, and someone has changed
a .template file, etc. you have no easy way tell.
The advantages and disadvantages of this depend on the deployment and maintenance strategy.
The BCDA currently uses subversion to track changes to most deployed modules, so being able to use git to see changes to deployed files provides little additional value. If we didn't already have a system, this would be a useful feature, though I would create a local "deployed" branch rather than run from the master, to minimize damage from accidental pushes.
If only one person is deploying and maintaining EPICS modules, running from a github clone for every module isn't a problem. If many people support EPICS modules and IOCs, the overhead of having to navigate to each EPICS module to type "git branch" to find out what versions of software an IOC is running is very painful and time consuming.
Kevin
AreaDetector repository inconsistent Jörn Dreyer
Re: AreaDetector repository inconsistent Ralph Lange
Re: AreaDetector repository inconsistent Jörn Dreyer
Re: AreaDetector repository inconsistent J. Lewis Muir
RE: AreaDetector repository inconsistent Mark Rivers
Re: AreaDetector repository inconsistent Pete Jemian
Re: AreaDetector repository inconsistent Mooney, Tim M.
Prev: RE: AreaDetector repository inconsistent Mark Rivers
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: Re: AreaDetector repository inconsistent J. Lewis Muir
ANJ, 08 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
