1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer seem to skip states with EPICS 3.16.1
To: [email protected]
Date: Wed, 7 Feb 2018 23:31:51 +0100
Hi again,
I am not sure, if this is completely related to that, but I see a connection.
This test now was done with EPICS7, but I can verify this tomorrow with EPICS3.16 as well:
I am using the sequencer on another part (not the state), here an excerpt:
>   state check {
>     when(pv_mem < 2) {
>     } state check_valid
>     when(pv_rate != 0) {
>     } state check
>     when(pv_rate == 0 && delay(Waittime)) {
>     } state check_failed
The idea is to stay in this state until pv_rate is 0 AND some delay. But the delay shall only start, when the rate is already 0. Therefore, I go into the same state to reset the timer. The -t option is not set!
The result is that as long as pv_rate is not 0, the IOC uses 100% cpu up to the point where the PV are getting disconnected. After pv_rate gets 0, it continues working.
With EPICS3.14 this was working fine.
This test was done with sequencer 2.2.4.
Best regards,
Simon
Simon Reiter
II. Physikalisches Institut
Justus-Liebig-Universität
Heinrich-Buff-Ring 16
D-35392 Giessen
Tel: +49 641 99 33250
Re: Sequencer seem to skip states with EPICS 3.16.1 Hartman, Steven M.
Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Re: Sequencer seem to skip states with EPICS 3.16.1 Andrew Johnson
Prev: RE: AreaDetector repository inconsistent Kevin Peterson
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
ANJ, 07 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
