1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer seem to skip states with EPICS 3.16.1
To: Andrew Johnson <[email protected]>, [email protected]
Date: Wed, 31 Jan 2018 23:31:45 +0100
>> I don't think we have a test for CA exactly like Benjamin described, but
>> there are a load of self-tests in Base which it would be good for you to
>> run on your target if you haven't already done so. Just cd to the top of
>> your Base source tree and type 'make -s runtests'. Don't worry about
>> warning or error messages from the tests running, they are normal; just
>> look for summaries at the end of a group of tests that say something
>> like "Result: FAIL" and copy/paste the details of the failures that show
>> up near that line. Hopefully there won't be any, but...
Here is the output:
> Test Summary Report
> Breaktable.t (Wstat: 512 Tests: 0 Failed: 0)
>   Non-zero exit status: 2
>   Parse errors: No plan found in TAP output
> DBD.t       (Wstat: 512 Tests: 0 Failed: 0)
> Device.t    (Wstat: 512 Tests: 0 Failed: 0)
> Driver.t    (Wstat: 512 Tests: 0 Failed: 0)
> Function.t  (Wstat: 512 Tests: 0 Failed: 0)
> macLib.t    (Wstat: 512 Tests: 0 Failed: 0)
> Menu.t      (Wstat: 512 Tests: 0 Failed: 0)
> Recfield.t  (Wstat: 512 Tests: 0 Failed: 0)
> Recordtype.t (Wstat: 512 Tests: 0 Failed: 0)
> Registrar.t (Wstat: 512 Tests: 0 Failed: 0)
> Snippets.t  (Wstat: 512 Tests: 0 Failed: 0)
> Variable.t  (Wstat: 512 Tests: 0 Failed: 0)
> Files=12, Tests=0,  0 wallclock secs ( 0.03 usr  0.00 sys +  0.04 cusr  0.01 csys =  0.08 CPU)
> Result: FAIL
> Failed 12/12 test programs. 0/0 subtests failed.
> ringPointerTest.t .......... 1/37 epicsThreadSetPriority called by non epics thread epicsThreadSetPriority called by non epics thread
> dbPutLinkTest.t ............ 256/301 dbJLinkInit: lexical error: invalid char in json text.
>                                   {"x":bbbb}
>                      (right here) ———^
> chfPluginTest.t ............ 1247/1433 chfConfigParseStart: plugin pvt alloc failed
Other tests are successful.
I hope, this helps you already
Best,
Simon
Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
Re: Sequencer seem to skip states with EPICS 3.16.1 Ralph Lange
Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Re: Sequencer seem to skip states with EPICS 3.16.1 Andrew Johnson
Prev: quadEM R9-1 now available Mark Rivers
Next: FLIR 10Gbit Ethernet camera question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Andrew Johnson
Next: Re: Sequencer seem to skip states with EPICS 3.16.1 Simon Reiter
ANJ, 31 Jan 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
