1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Data format using NDFileHDF5
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Thu, 8 Feb 2018 14:51:29 +0000
Hi Steve,
As Mark mention; no we can't do that with the NDFileHDF5 plugin - and it differs from fundamental principles in how we currently write NDArrays and NDAttributes to HDF5 files.
Here at Diamond we write additional HDF5/NeXus files using a supervisory process application where HD5 External Links [1], or in more recent cases VDS [2], is used to link and re-shape the data without copying it for application-specific purposes.
It is a pretty complex topic, come and see me or Alan Greer about this when you're next at Diamond :-)
Cheers,
Ulrik
[1]: https://support.hdfgroup.org/HDF5/doc/RM/RM_H5L.html
[2]: https://support.hdfgroup.org/HDF5/docNewFeatures/NewFeaturesVirtualDatasetDocs.html
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 08 February 2018 12:02
To: Kinder, Steve (STFC,DL,TECH) <[email protected]>; [email protected]
Subject: Re: Data format using NDFileHDF5
Hi Steve,
> They would however like what I think is a list of separate 2D arrays with the attributes directly connected to each array they are relevant to.
I don't think you can do that via the XML layout file with the existing NDFileHDF5 plugin.  When collecting NumArrays arrays into a single HDF5 file the plugin creates an image array [NX, NY, [NZ, etc.], NumArrays], and for each attribute a 1-D array [NumArrays].
I believe the NDPosPlugin allows you to fill in those arrays non-sequentially, for example to handle a bi-directional "snake scan", but the array structure is fixed.
The simplest solution would be a post-processing program in Python, etc. that re-structures the array into a new HDF5 file.  The plugin is already fairly complex, so it may not be trivial to add that feature.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, February 8, 2018 3:15 AM
To: [email protected]
Subject: Data format using NDFileHDF5
I am using the NDFileHDF5 areaDetector plugin to write data and attributes collected from PCO cameras. I've been able to store data and attributes using XML files to define the attributes of interest and the following for the HDF5 layout:
<entry>
  <group name="Data" ndattr_default="true">
    <dataset name="Images" source="detector" det_default="true"></dataset>
  </group>
</entry>
My end user sees this as a 3D data array with separate attributes which seemed fine. They would however like what I think is a list of separate 2D arrays with the attributes directly connected to each array they are relevant to. I've spent some time trying to figure out how to do that via the XML layout file but not got there yet. I will continue but I am beginning to wonder whether I will have to modifiy the plugin source.
In the meantime I wondered whether anyone had an example XML layout file that might help me get the desired structure? Or advice on whether the plugin will need modifying?
Thanks
Steve
Re: Data format using NDFileHDF5 steve.kinder
Re: Data format using NDFileHDF5 Mark Rivers
Prev: Re: Sequencer seem to skip states with EPICS 3.16.1 Benjamin Franksen
Next: Re: Why is post_event deprecated? Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Data format using NDFileHDF5 Mark Rivers
Next: Re: Data format using NDFileHDF5 steve.kinder
ANJ, 14 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
