1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Autosave -- debug output when field is updated
To: "Rivers, Mark L." <[email protected]>, "'Daykin, Evan'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 13 Feb 2018 20:01:28 +0000
What Mark said.  But also, we had a situation recently in which several PVs were being posted at hundreds of HZ, and just having monitors on those PVs used a surprising amount of CPU.  (We had a calcout record with CP links to the rapidly posted PVs.  When we prevented the calcout record from processing, CPU went down, of course, but only to around 30%.  When we deleted the links, the CPU went down to a normal range.)  (Autosave monitors the PVs it saves, though I don't know if its monitor processing is comparable to an input link's monitor processing.)
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Mark Rivers <[email protected]>
Sent: Tuesday, February 13, 2018 1:32:27 PM
To: 'Daykin, Evan'; [email protected]
Subject: RE: Autosave -- debug output when field is updated
Hi Evan,
Note that the rate at which the PV updates and the rate at which the autosave file is written are quite different things.  I don’t think it would use a lot of CPU for the PV to update rapidly when the file is only being written every 30 seconds or so.  But perhaps I am wrong?
From: [email protected] [mailto:[email protected]] On Behalf Of Daykin, Evan
Sent: Tuesday, February 13, 2018 12:50 PM
To: [email protected]
Subject: Autosave -- debug output when field is updated
Hello,
Apologies in advance if this is in the documentation somewhere, I was unable to find it.
We have an IOC which uses quite a lot of CPU when autosave is turned on. This is most likely the result of some inadvertently autosaved fields being updated at 100Hz. Is there a straightforward way, such as an IOC shell command, to print some debug output whenever an autosaved field is written?
Best,
Evan
Autosave -- debug output when field is updated Daykin, Evan
RE: Autosave -- debug output when field is updated Mark Rivers
Prev: RE: SMA100A Signal Generatordriver Ha, Kiman
Next: Re: Possible issue with epics-base 7 compilation Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Autosave -- debug output when field is updated Mark Rivers
Next: "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
ANJ, 14 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
