1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Inspect Waveforms" in CSS DataBrowser
To: Takashi OBINA <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 14 Feb 2018 14:05:45 +0000
Hello:
>Is there any method to fix the vertical scale in "Inspect Waveforms" panel of the CSS DataBrowser?
>The vertical axis is always scaled automatically, and I cannot find the way to change it manually.
> I've tested with SNS version 4.5.0 (Basic EPICS).
If you use the latest download, the left-most plot  toolbar button opens a configuration dialog for the axis range.
In addition, you can double-click on the start or end of the axis which turns the axis number into a text entry field where you can then enter the desired value.
-Kay
Attachment: wf.png
Description: wf.png
Re: "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
Prev: "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
Next: CA Client crash after "too many open files" error Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: "Inspect Waveforms" in CSS DataBrowser Takashi OBINA
ANJ, 14 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
