1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Inspect Waveforms" in CSS DataBrowser
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 15 Feb 2018 00:22:47 +0900
Hello Kay,
Thank you very much for your information.
I confirmed that the latest build has the setting panel.
Also, double-clicking at the end of the axis is a nice idea!
Both methods work fine.
Thanks.
Takashi Obina
On 2018/02/14 23:05, Kasemir, Kay wrote:
Hello:
Is there any method to fix the vertical scale in "Inspect Waveforms" panel of the CSS DataBrowser?
The vertical axis is always scaled automatically, and I cannot find the way to change it manually.
I've tested with SNS version 4.5.0 (Basic EPICS).
If you use the latest download, the left-most plot  toolbar button opens a configuration dialog for the axis range.
In addition, you can double-click on the start or end of the axis which turns the axis number into a text entry field where you can then enter the desired value.
-Kay
Takashi OBINA ([email protected])
  Phone 029-864-5200 -> 4526;  Fax: 029-864-2801
"Inspect Waveforms" in CSS DataBrowser Takashi OBINA
Re: "Inspect Waveforms" in CSS DataBrowser Kasemir, Kay
Prev: CA Client crash after "too many open files" error Dirk Zimoch
Next: Re: CA Client crash after "too many open files" error Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "Inspect Waveforms" in CSS DataBrowser Kasemir, Kay
Next: CA Client crash after "too many open files" error Dirk Zimoch
ANJ, 14 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
