I like #2. I think this patch ought to do it. It seems that the upstream tpmac project is not on Github, who should I submit this to?Bruno On Thu, Feb 15, 2018 at 12:37 PM, Mark Rivers <[email protected]> wrote:
diff --git a/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp b/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp index 36cc123..aba5b37 100644 --- a/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp +++ b/pmacApp/pmacAsynMotorPortSrc/pmacController.cpp @@ -322,23 +322,19 @@ asynStatus pmacController::lowLevelWriteRead(const char *command, char *response //Use the controller-wide param PMAC_C_CommsError_ getIntegerParam(PMAC_C_CommsError_, &commsError); - status = pasynOctetSyncIO->writeRead(lowLevelPortUser_ , + if (!commsError) { + status = pasynOctetSyncIO->writeRead(lowLevelPortUser_ , command, strlen(command), response, PMAC_MAXBUF_, PMAC_TIMEOUT_, &nwrite, &nread, &eomReason ); - if (status) { - asynInterface *pasynInterface = pasynManager->findInterface(lowLevelPortUser_, - asynCommonType, true); - asynCommon *pasynCommon = (asynCommon*) pasynInterface->pinterface; - - asynPrint(lowLevelPortUser_, ASYN_TRACE_ERROR, "%s: Error from pasynOctetSyncIO->writeRead. command: %s, status=%d\n", functionName, command, status); - setIntegerParam(PMAC_C_CommsError_, PMAC_ERROR_); - pasynCommon->disconnect(pasynInterface->drvPvt, lowLevelPortUser_); - - } else { - setIntegerParam(PMAC_C_CommsError_, PMAC_OK_); + if (status) { + asynPrint(lowLevelPortUser_, ASYN_TRACE_ERROR, "%s: Error from pasynOctetSyncIO->writeRead. command: %s\n", functionName, command); + setIntegerParam(PMAC_C_CommsError_, PMAC_ERROR_); + } else { + setIntegerParam(PMAC_C_CommsError_, PMAC_OK_); + } } asynPrint(lowLevelPortUser_, ASYN_TRACEIO_DRIVER, "%s: response: %s\n", functionName, response);
ANJ, 15 Feb 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
