1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using stream -calcout
To: <[email protected]>
Date: Mon, 19 Feb 2018 17:59:16 +0100
Hello Li Xing,
I suggest to use a numeric record to receive the numbers, either longin if you want the integer or ai if you want to convert (scale) the integer to a double.
For clarifications: Do you send "\xFE\x04\x00\x00\x00\x01\x25\xC5" (8 bytes) or " fe 04 00 00 00 01 25 c5 " (string with 25 chars coding for 8 hex numbers)?
From your protocol I assume that you have 8 raw bytes, not a hex string.
To read 2 raw bytes as an integer use "%2r" (big endian signed) or "%02r" (big endian unsigned), "%#2r" (little endian signed) or "%#02r" (little endian unsigned). I assume big endian unsigned for now.
record(longin, "TEM") {
      field(DESC, "test for upstairs tcpip")
      field(DTYP, "stream")
      field(INP,  "@devtemp.proto get_high $(PORT) $(A)")
get_tem {
     MaxInput = 7;
     out "\xFE\x04\x00\x00\x00\x01\x25\xC5";
     in 0xfe 0x04 0x02 "%02r" 0xae 0x22;
This should give you 1032.
I assuming the input always starts with 0xfe 0x04 0x02 and always ends with 0xae 0x22. If the last two bytes are some sort of checksum consider the %<...> formats. I set MaxInput = 7; to avoid delays from readTimeout because you have no terminator and seem to have fixed input length of 7 bytes.
Dirk
On 16.02.2018 11:27, l123173 wrote:
Hi all,
      I have a simple question about stream.
     The device was connected with LAN. If sending " fe 04 00 00 00 01 25 c5 " in Hex,  getting  " fe 04 02 04 08 ae 22 " in Hex.      Among the getting bytes( " fe 04 02 04 08 ae 22 "), 04 08 was I wanted. Convert  0408(HEX) to decimal was 1032 (4*16**2 +8=1032), and 1032 was the finall result I wanted.     In my programe, I have successfully sent and got the bytes. But I could not get the 1032, I want to achieve it using scalcout, but failed.
     Could you please give me some suggestion.
     The environment I use, base3.14.12.7, synapps_5_8, fedora 27(64).
my db file:
record(stringin, "GET_HIGH")
record(stringin, "GET_LOW")
     field(INP,  "@devtemp.proto get_low $(PORT) $(A)")
     field(SCAN, "I/O Intr")
record(scalcout, "TEM")
     field(DESC, "get the temperature")
     field(INPA, "GET_HIGH")
     field(INPB, "GET_LOW")
     field(CALC, "A*16*16 + B")
my proto file:
get_high {
    in "%*c%*c%*c%*c%*c%*c%c%c%*c%*c%*c%*c%*c%*c";
#   in "%s";
get_low {
    in "%*c%*c%*c%*c%*c%*c%*c%*c%c%c%*c%*c%*c%*c";
output of  st.cmd: (there is an error "Record "TEM" is of unknown type "scalcout" )
#!../../bin/linux-x86_64/temp
## You may have to change temp to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","ioctemp")
epicsEnvSet("TOP","/home/lyx/tem_setup_with_asyn_scpi")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ASYN","/opt/epics/synApps_5_8/support/asyn-4-26")
epicsEnvSet("STREAM","/opt/epics/synApps_5_8/support/stream-2-6a")
epicsEnvSet "STREAM_PROTOCOL_PATH"  "/home/lyx/tem_setup_with_asyn_scpi/db"
epicsEnvSet "P" "P"
epicsEnvSet "R" "T"
cd "/home/lyx/tem_setup_with_asyn_scpi"
dbLoadDatabase "dbd/temp.dbd"
temp_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("L0","192.168.215.120:10000",0,0,0)
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
## Load record instances
dbLoadRecords("/home/lyx/tem_setup_with_asyn_scpi/db/devtemp.db","P=P,R=T,PORT=L0,A=0,user=lyxHost")
Error at or before ")" in file "/home/lyx/tem_setup_with_asyn_scpi/db/devtemp.db" line 25
cd "/home/lyx/tem_setup_with_asyn_scpi/iocBoot/ioctemp"
iocInit
Starting iocInit
## EPICS R3.14.12.7
## EPICS Base built Feb  7 2018
Li xing
using stream -calcout l123173
Prev: RE: Excel DDE to EPICS interface freddie.akeroyd
Next: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: using stream -calcout Ralph Lange
Next: Re: using stream -calcout l123173
ANJ, 20 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
