1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s)
Cc: "Gofron, Kazimierz" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Feb 2018 11:24:21 -0600
Hi Mark,
On 02/18/2018 08:19 AM, Mark Rivers wrote:
> We have established that the files do contain these non-UTF8
> characters.  The question is, should this matter?  So far the only
> problem has been observed by Kaz when building on Windows.  The problem
> is in perl when creating the .d dependency files.
> My conclusion is that the characters are not a problem when using perl
> 5.14.2 or 5.16.3, but they are a problem when using perl 5.24.3.  Is
> there a switch to later versions of perl that would suppress this error?
It should be possible to tell Perl to suppress its Unicode handling. Try
adding this to the build, either to some appropriate CONFIG_SITE* file,
or (my preference) to the Makefile that builds the problematic source files:
    # Sources here use a non-UTF-8 encoding
    PERL = perl -C0
Our default -CSD setting tells Perl that all I/O streams should be
assumed to use UTF-8 encoding; -C0 says no I/O streams use UTF-8. I
would like the EPICS default to continue to use UTF-8 if possible.
- Andrew
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Johnson, Andrew N.
Prev: Re: using stream -calcout Dirk Zimoch
Next: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Torsten Bögershausen
ANJ, 19 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
