1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s)
To: "Rivers, Mark L." <[email protected]>
Cc: "Gofron, Kazimierz" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 18 Feb 2018 00:32:52 +0000
Hi,Mark,
When you got the original source file it was probably not encoded as UTF-8. Converting it from whatever encoding it did use to UTF-8 wouldn’t really be changing the meaning of the files. The upstream repo may not even know that they have this problem, but you’ll probably want to ask them what encoding they think they’re using and maybe offer them a fixed version or this file if they want it to be UTF-8 (or change the smart quotes to regular ones instead).
- Andrew
Sent from my iPad
On Feb 17, 2018, at 2:29 PM, Mark Rivers <[email protected]> wrote:
I will fix these files to remove the offending characters since it seems to cause Perl to fail.
On second thought I would like to get input from Andrew Johnson or others on whether it would be possible to have Perl simply not generate the fatal error in this case.  I am reluctant to change those files, because they are from the GraphicsMagick distribution, and then we need to patch them each time we get a new release.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf
Of Mark Rivers
Sent: Saturday, February 17, 2018 2:18 PM
To: 'Gofron, Kazimierz' <[email protected]>; [email protected]
Subject: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
character(s)
I have determined that whether or not the non-UTF8 characters are detected depends on the
version of Linux on which grep is running.
I just searched all of ADSupport on an RHEL 7 system and it did not find anything.
[epics@corvette ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
I then did the search on exactly the same physical files, but running the command on a
Fedora 26 system that has this file system NFS mounted:
[epics@millenia ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c:                               // measurement.
Allowed values are ▒black▒, ▒white▒, or {"na".
./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c:                               // values are
{"yes▒, ▒white▒, ▒none▒ or ▒na▒.
./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c:        // In this particular optimization,
cach▒ does not help as it takes more time to deal with
./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c:        // the cach▒ that with the pixel
handling
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:    //(see clause 4.1 for the definition
of ▒aligned▒). Because the Unicode language
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The device representation
corresponds to the header▒s ▒color space of data▒ field.
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://This representation should be
consistent with the ▒number of device components▒
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The PCS representation corresponds
to the header▒s PCS field. The PCS representation
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://CIE ▒absolute▒ illuminant white
point tristimulus values and CIE ▒absolute▒
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// The first curve segment always
starts at ▒Infinity, and the last curve segment always ends at +Infinity. The
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// array = [e11, e12, ▒, e1P, e21, e22,
▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:            // Y = (Max ▒ Min) * (X ^
Gamma) + Min
./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:            // a = (Max ▒ Min) ^ ( 1 /
Gamma)
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://If  R▒sRGB,G▒sRGB, B▒sRGB <
0.04045
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    R =  R▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    G =  G▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    B =  B▒sRGB / 12.92
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://else if  R▒sRGB,G▒sRGB, B▒sRGB
= 0.04045
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    R = ((R▒sRGB + 0.055) /
1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    G = ((G▒sRGB + 0.055) /
1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    B = ((B▒sRGB + 0.055) /
1.055)^2.4
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Null transformation, only applies
formatters. No cach▒
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Gamut check, No cach▒, 16 bits.
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// No gamut check, Cach▒, 16 bits,
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:            // Float transforms don't use
cach▒, always are non-NULL
./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:                    p ->xform =
PrecalculatedXFORMGamutCheck;  // Gamut check, no cach▒
PrecalculatedXFORM;  // No cach▒, no gamut check
CachedXFORMGamutCheck;    // Gamut check, cach▒
CachedXFORM;  // No gamut check, cach▒
./supportApp/GraphicsMagickSrc/magick/cdl.c: * Original implementation by Cl▒ment
Follet.  Additional work by Bob
./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToAbsolute() draws a
cubic B▒zier curve from the current
./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToRelative() draws a
DrawPathCurveToQuadraticBezierAbsolute() draws a quadratic B▒zier curve
DrawPathCurveToQuadraticBezierRelative() draws a quadratic B▒zier curve
./supportApp/GraphicsMagickSrc/magick/draw.c:%  B▒zier curve (using absolute
coordinates) from the current point to
./supportApp/GraphicsMagickSrc/magick/draw.c:%  B▒zier curve (using relative
./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToSmoothAbsolute()
draws a cubic B▒zier curve from the
./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToSmoothRelative()
./supportApp/GraphicsMagickSrc/magick/hclut.c:%  GraphicsMagick by Cl▒ment Follet
with support from C▒dric Lejeune of
./supportApp/GraphicsMagickSrc/wmf/src/extra/gd/gdtestft.c:  char *s = "Hello.
▒▒▒▒ɂ▒▒▒ Qyjpqg,";       /* String to draw. */
Sent: Saturday, February 17, 2018 11:59 AM
To: Mark Rivers <[email protected]>; [email protected]
character(s)
Could you please check if those characters are actually converted to UTF8 on your RHEL
7.
Form windows/linux google-chrome, I am seeing these characters in the github.com. I
copy/past them into the
https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lc
ms/src/cmstypes.c#L965
I copy/past these characters into the UTF8 tool:
https://sites.google.com/site/nathanlexwww/tools/utf8-convert
I am seeing them as 6byte instead of usual 2Byte on the github.
Sent: Saturday, February 17, 2018 12:48 PM
To: Gofron, Kazimierz; [email protected]
character(s)
Any idea why my RHEL 7 system behaves differently from your Debian 8 system?  Is it
an
OS language setting?
Sent: Saturday, February 17, 2018 11:35 AM
To: Mark Rivers; [email protected]
character(s)
Hi Mark,
The non UTF8 characters are seen on linux as well.
1.       Debian 9 in VirtualBox on Windows 7 host.
kaz@stretch64:~/epics/ADSupport$ uname -a
Linux stretch64 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u5 (2017-09-19) x86_64
GNU/Linux
kaz@stretch64:~/epics$ git clone https://github.com/areaDetector/ADSupport ADSupport
Cloning into 'ADSupport'...
remote: Counting objects: 7063, done.
remote: Compressing objects: 100% (3/3), done.
remote: Total 7063 (delta 0), reused 1 (delta 0), pack-reused 7060
Receiving objects: 100% (7063/7063), 25.59 MiB | 3.38 MiB/s, done.
Resolving deltas: 100% (3660/3660), done.
kaz@stretch64:~/epics$ cd ADSupport/
kaz@stretch64:~/epics/ADSupport$ git branch -a
* master
 remotes/origin/HEAD -> origin/master
 remotes/origin/hdf5-1.10.1-pre1
 remotes/origin/hdf5-1.10.1-pre2
 remotes/origin/master
kaz@stretch64:~/epics/ADSupport$ grep -n -axv '.*'
965:    //(see clause 4.1 for the definition of �aligned�). Because the Unicode language
3063://The device representation corresponds to the header�s �color space of data�
field.
3064://This representation should be consistent with the �number of device components�
3066://The PCS representation corresponds to the header�s PCS field. The PCS
representation
3811://CIE �absolute� illuminant white point tristimulus values and CIE �absolute�
3898:// The first curve segment always starts at �Infinity, and the last curve segment
always
4174:// array = [e11, e12, �, e1P, e21, e22, �, e2P, �, eQ1, eQ2, �, eQP, e1, e2, �, eQ]
4673:            // Y = (Max � Min) * (X ^ Gamma) + Min
4676:            // a = (Max � Min) ^ ( 1 / Gamma)
2.       Server , debian 8
kgofron@xf18id-srv2:~/test/ADSupport$ uname -a
Linux xf18id-srv2 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19)
x86_64
GNU/Linux
kgofron@xf18id-srv2:~/test$ git clone https://github.com/areaDetector/ADSupport
Receiving objects: 100% (7063/7063), 25.59 MiB | 5.94 MiB/s, done.
Checking connectivity... done.
kgofron@xf18id-srv2:~/test$ cd ADSupport
kgofron@xf18id-srv2:~/test/ADSupport$ git branch -a
* master
kgofron@xf18id-srv2:~/test/ADSupport$ grep -n -axv '.*'
field.
representation
always
Kaz
Sent: Saturday, February 17, 2018 11:40 AM
character(s)
Hi Kaz,
I cannot reproduce your grep of the non-UTF-8 characters.  Here is a fresh clone and a
grep
on an RHEL 7 system.  The grep command is a copy and paste from your e-mail.
[epics@corvette scratch]$ git clone
[email protected]:areaDetector/ADSupport<mailto:[email protected]:areaDetector/ADSupport
Receiving objects: 100% (7063/7063), 25.59 MiB | 29.57 MiB/s, done.
[epics@corvette scratch]$ cd ADSupport/supportApp/GraphicsMagickSrc/lcms/src/
[epics@corvette src]$ grep -n -axv '.*' cmstypes.c
What do you see if you follow these steps on a Linux system?
Sent: Saturday, February 17, 2018 9:31 AM
To: Mark Rivers <[email protected]<mailto:[email protected]>>; tech-
character(s)
Hi Mark,
After changing to master branch (was in detached HEAD), I confirmed that the
cmstypes.c
has the UTF8 problem.
Sqr-1 IXS@IXS_MCM /cygdrive/c/epics/synApps/support/areaDetector-3-
2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src
965:    //(see clause 4.1 for the definition of ▒aligned▒). Because the Unicode language
3063://The device representation corresponds to the header▒s ▒color space of data▒
field.
3064://This representation should be consistent with the ▒number of device components▒
3066://The PCS representation corresponds to the header▒s PCS field. The PCS
representation
3811://CIE ▒absolute▒ illuminant white point tristimulus values and CIE ▒absolute▒
3898:// The first curve segment always starts at ▒Infinity, and the last curve segment
always
4174:// array = [e11, e12, ▒, e1P, e21, e22, ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
4673:            // Y = (Max ▒ Min) * (X ^ Gamma) + Min
4676:            // a = (Max ▒ Min) ^ ( 1 / Gamma)
Now your steps:
-----------------------------------Step 1
c:\epics\synApps\support\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc
\lcms\src>git status .
On branch master
Your branch is up to date with 'origin/master'.
nothing to commit, working tree clean
----------------------------------  Step 2
a)       {I do not have the O.windows-x64-static-vs2017 directory}
2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>ls -l
total 1240
-rw-r--r-- 1 Sqr-1 IXS 197121   1484 Feb 16 15:21 Makefile
-rw-r--r-- 1 Sqr-1 IXS 197121    945 Feb 16 15:21 Makefile.am
-rw-r--r-- 1 Sqr-1 IXS 197121  24192 Feb 16 15:21 Makefile.in
drwxr-xr-x 1 Sqr-1 IXS 197121      0 Feb 17 10:16 O.Common
drwxr-xr-x 1 Sqr-1 IXS 197121      0 Feb 17 10:16 O.windows-x64-static
-rw-r--r-- 1 Sqr-1 IXS 197121  16076 Feb 16 15:21 cmsalpha.c
-rw-r--r-- 1 Sqr-1 IXS 197121  14439 Feb 16 15:21 cmscam02.c
-rw-r--r-- 1 Sqr-1 IXS 197121  75151 Feb 16 15:21 cmscgats.c
-rw-r--r-- 1 Sqr-1 IXS 197121  43741 Feb 16 15:21 cmscnvrt.c
-rw-r--r-- 1 Sqr-1 IXS 197121  21630 Feb 16 15:21 cmserr.c
-rw-r--r-- 1 Sqr-1 IXS 197121  38551 Feb 16 15:21 cmsgamma.c
-rw-r--r-- 1 Sqr-1 IXS 197121  20565 Feb 16 15:21 cmsgmt.c
-rw-r--r-- 1 Sqr-1 IXS 197121  35846 Feb 16 15:21 cmshalf.c
-rw-r--r-- 1 Sqr-1 IXS 197121  45687 Feb 16 15:21 cmsintrp.c
-rw-r--r-- 1 Sqr-1 IXS 197121  60115 Feb 16 15:21 cmsio0.c
-rw-r--r-- 1 Sqr-1 IXS 197121  36128 Feb 16 15:21 cmsio1.c
-rw-r--r-- 1 Sqr-1 IXS 197121  53169 Feb 16 15:21 cmslut.c
-rw-r--r-- 1 Sqr-1 IXS 197121   9806 Feb 16 15:21 cmsmd5.c
-rw-r--r-- 1 Sqr-1 IXS 197121   5858 Feb 16 15:21 cmsmtrx.c
-rw-r--r-- 1 Sqr-1 IXS 197121  29205 Feb 16 15:21 cmsnamed.c
-rw-r--r-- 1 Sqr-1 IXS 197121  66034 Feb 16 15:21 cmsopt.c
-rw-r--r-- 1 Sqr-1 IXS 197121 112503 Feb 16 15:21 cmspack.c
-rw-r--r-- 1 Sqr-1 IXS 197121  26406 Feb 16 15:21 cmspcs.c
-rw-r--r-- 1 Sqr-1 IXS 197121  28939 Feb 16 15:21 cmsplugin.c
-rw-r--r-- 1 Sqr-1 IXS 197121  48476 Feb 16 15:21 cmsps2.c
-rw-r--r-- 1 Sqr-1 IXS 197121  18399 Feb 16 15:21 cmssamp.c
-rw-r--r-- 1 Sqr-1 IXS 197121  19820 Feb 16 15:21 cmssm.c
-rw-r--r-- 1 Sqr-1 IXS 197121 186719 Feb 17 09:34 cmstypes.c
-rw-r--r-- 1 Sqr-1 IXS 197121  38122 Feb 16 15:21 cmsvirt.c
-rw-r--r-- 1 Sqr-1 IXS 197121  11330 Feb 16 15:21 cmswtpnt.c
-rw-r--r-- 1 Sqr-1 IXS 197121  49131 Feb 16 15:21 cmsxform.c
-rw-r--r-- 1 Sqr-1 IXS 197121  22867 Feb 16 15:21 lcms2.def
-rw-r--r-- 1 Sqr-1 IXS 197121  37465 Feb 16 15:21 lcms2_internal.h
b)
2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del O.windows-x64-static-
vs2017\cmstypes.obj
The system cannot find the file specified.
c)
2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>make
make -C O.windows-x64-static -f ../Makefile TOP=../../../../.. \
   T_A=windows-x64-static install
make[1]: Entering directory 'c:/epics/synApps/support/areaDetector-3-
2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static'
perl -CSD c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl  -m cmstypes.d -I. -
I../O.Common -I. -I. -I.. -I../../../../../include/compiler
/msvc -I../../../../../include/os/WIN32 -I../../../../../include      -
IC:/epics/synApps/support/asyn-
R4-33/include     -IC:/epics/synApps/s
upport/areaDetector-3-2/ADSupport/include/os/WIN32 -
IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include   -
t/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0.1/include/compiler/msvc -
Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-7.0.1/i
nclude     -I../../../../../supportApp/GraphicsMagickSrc/lcms/include    cmstypes.obj
../cmstypes.c
Malformed UTF-8 character (fatal) at c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl
line 137, <FILE> line 5573.
make[1]: Nothing to be done for 'install'.
make[1]: Leaving directory 'c:/epics/synApps/support/areaDetector-3-
a2)
2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>del
cmstypes.obj
2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>cd ..
../cmstypes.c
cl               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -
D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3     -D_LCMSLIB_ -DWIN64
D_VIS
UALC_ -D_LIB    -MT    -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/msvc -
/../include      -IC:/epics/synApps/support/asyn-R4-33/include     -
IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/WIN32 -I
IC:/epics/synApps/support/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0
.1/include/compiler/msvc -Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-
7.0.1/include     -I../../../../../supportApp/GraphicsMagick
Src/lcms/include    -c ../cmstypes.c
cmstypes.c
lib -nologo -verbose -out:lcms.lib         cmsalpha.obj cmscam02.obj cmscgats.obj
cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.ob
j cmsintrp.obj cmsio0.obj cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj
cmsopt.obj cmspack.obj cmspcs.obj cmsplugin.obj cmsps2.o
bj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj cmswtpnt.obj cmsxform.obj
Appending cmsxform.obj
Appending cmswtpnt.obj
Appending cmsvirt.obj
Appending cmstypes.obj
Appending cmssm.obj
Appending cmssamp.obj
Appending cmsps2.obj
Appending cmsplugin.obj
Appending cmspcs.obj
Appending cmspack.obj
Appending cmsopt.obj
Appending cmsnamed.obj
Appending cmsmtrx.obj
Appending cmsmd5.obj
Appending cmslut.obj
Appending cmsio1.obj
Appending cmsio0.obj
Appending cmsintrp.obj
Appending cmshalf.obj
Appending cmsgmt.obj
Appending cmsgamma.obj
Appending cmserr.obj
Appending cmscnvrt.obj
Appending cmscgats.obj
Appending cmscam02.obj
Appending cmsalpha.obj
Installing library ../../../../../lib/windows-x64-static/lcms.lib
My installation is cloned directly to Windows from github, but previously I cloned to
debian9 virtual machine, and copied through shared folder to Windows with same
compile
errors. The compilation is reproducible on two Windows 7 systems.
-Kaz
Sent: Saturday, February 17, 2018 8:26 AM
To: Gofron, Kazimierz; [email protected]<mailto:[email protected]>
character(s)
Hi Kaz,
I just tested compiling that file on my system.  The following shows that I am using the
git
master version of that file, and that I don’t get any error compiling it with VS 2017.  Can
you please execute these exact same 3 commands on your system?  Check out the master
branch first.  In the output below I inserted line breaks into the cl output to make it easier
to
read.
One difference could be that my working directory is on a Linux system, not on a
Windows
system.  I have the Linux file system mounted from the Windows machine.  Perhaps there
is
some character translation happening either with the git checkout on Linux, or when
serving
the files to Windows?
J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>git
status .
On branch master
Your branch is up-to-date with 'origin/master'.
J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del
O.windows-x64-static-vs2017\cmstypes.obj
make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../../../.. \
   T_A=windows-x64-static-vs2017 install
make[1]: Entering directory 'J:/epics/devel/areaDetector-3-
2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static-vs2017'
-D_LCMSLIB_ -DWIN64 -D_VISUALC_ -D_LIB    -MT    -I. -I../O.Common
-I. -I. -I.. -I../../../../../include/compiler/msvc -I../../../../../include/os/WIN32 -
-IJ:/epics/devel/asyn-4-33/include/compiler/msvc  -IJ:/epics/devel/asyn-4-33/include
-IJ:/epics/devel/areaDetector-3-2/ADSupport/include/os/WIN32 -
-IJ:/epics/devel/areaDetector-3-2/ADCore/include -IH:/epics-devel/base-
-IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include
-I../../../../../supportApp/GraphicsMagickSrc/lcms/include    -c ../cmstypes.c
cmstypes.c
cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.obj cmsintrp.obj cmsio0.obj
cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj cmsopt.obj cmspack.obj
cmspcs.obj cmsplugin.obj cmsps2.obj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj
Appending cmssm.obj
"Installing library ../../../../../lib/windows-x64-static-vs2017/lcms.lib"
make[1]: Leaving directory 'J:/epics/devel/areaDetector-3-
Sent: Saturday, February 17, 2018 7:03 AM
character(s)
Hi Mark,
The ADSupport compilation error is originating from non compatible UTF-8 characters in
cmstypes.c file. That compilation error went away after changing characters to UTF-8
format.
For now, I placed a UTF-8 compatible file here:
https://github.com/kgofron/synAppsRelease/blob/master/SCRIPTS/ADSupportRepair/cmsty
pes.c
I wonder whether you have another installation of GraphicsMagick on your system.
The characters not following UTF-8 format are on following lines of cmstypes.c file. I
checked few and they have 24 bit/6byte, instead of 2Byte(UTF-8). They are in comments
area, and typically are left-quote/right-quote, ellipses single character (…), elongated
minus,
etc.
ms/src/cmstypes.c#L3063
ms/src/cmstypes.c#L3064
ms/src/cmstypes.c#L3066
ms/src/cmstypes.c#L3811
ms/src/cmstypes.c#L3898
ms/src/cmstypes.c#L4174
ms/src/cmstypes.c#L4673
ms/src/cmstypes.c#L4676
UTF8<=> converter
Line 965 1st non-compatible character uses left quote (Hex C293220A,
RFC4648:wpMK).
-Kaz
Sent: Friday, February 16, 2018 11:46 PM
character(s)
There is a compilation error when compiling ADSupport  of areaDetector 3.2 with base-
7.
This error is related to GraphicsMagic.
I cannot reproduce that problem.  I have rebuilt ADSupport several times and the strings
“Malformed” or “UTF-8” do not occur in the output.  I used “make –sj8”.  I am using the
master branch of ADSupport.
I am using the same setup as Kaz:
base-7.0.1.1
VisualStudio 2017
make-4.2.1
Windows 7 Pro 64 bit
windows-x64-static
I do note that by switching to make 4.2.1 I no longer see the hangup when using “make –
sj”
which I did see with make 4.1.  make 4.1 would always hang when building
ADSupport/supportApp/hdf5Src with with make –sj.  It did always work with make –sj8.
[mailto:tech-
[email protected]] On Behalf Of Gofron, Kazimierz
Sent: Friday, February 16, 2018 9:31 PM
To: [email protected]<mailto:[email protected]>
Cc: Gofron, Kazimierz <[email protected]<mailto:[email protected]>>
Subject: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
character(s)
There is a compilation error when compiling ADSupport  of areaDetector 3.2 with base-7.
base-7.0.1.1
VisualStudio 2017
make-4.2.1
windows-x64-static
When compiling ADSupport, the following error is displayed twice:
Appending buf.obj
line 136, <FILE> line 5573.
jbig.c
BZIP compiling as library
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Prev: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Maren Purves
Next: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Next: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
ANJ, 18 Feb 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
