1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s)
To: Mark Rivers <[email protected]>, "'Gofron, Kazimierz'" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 17 Feb 2018 20:29:01 +0000
> I will fix these files to remove the offending characters since it seems to cause Perl to fail.
On second thought I would like to get input from Andrew Johnson or others on whether it would be possible to have Perl simply not generate the fatal error in this case.  I am reluctant to change those files, because they are from the GraphicsMagick distribution, and then we need to patch them each time we get a new release.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Mark Rivers
> Sent: Saturday, February 17, 2018 2:18 PM
> To: 'Gofron, Kazimierz' <[email protected]>; [email protected]
> character(s)
> I have determined that whether or not the non-UTF8 characters are detected depends on the
> version of Linux on which grep is running.
> I just searched all of ADSupport on an RHEL 7 system and it did not find anything.
> [epics@corvette ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
> I then did the search on exactly the same physical files, but running the command on a
> Fedora 26 system that has this file system NFS mounted:
> [epics@millenia ADSupport]$ find . -type f -name '*.c*' -exec grep -H -axv '.*' {} \;
> ./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c:                               // measurement.
> Allowed values are ▒black▒, ▒white▒, or {"na".
> ./supportApp/GraphicsMagickSrc/lcms/src/cmscgats.c:                               // values are
> {"yes▒, ▒white▒, ▒none▒ or ▒na▒.
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c:        // In this particular optimization,
> cach▒ does not help as it takes more time to deal with
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsopt.c:        // the cach▒ that with the pixel
> handling
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:    //(see clause 4.1 for the definition
> of ▒aligned▒). Because the Unicode language
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The device representation
> corresponds to the header▒s ▒color space of data▒ field.
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://This representation should be
> consistent with the ▒number of device components▒
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://The PCS representation corresponds
> to the header▒s PCS field. The PCS representation
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c://CIE ▒absolute▒ illuminant white
> point tristimulus values and CIE ▒absolute▒
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// The first curve segment always
> starts at ▒Infinity, and the last curve segment always ends at +Infinity. The
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:// array = [e11, e12, ▒, e1P, e21, e22,
> ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:            // Y = (Max ▒ Min) * (X ^
> Gamma) + Min
> ./supportApp/GraphicsMagickSrc/lcms/src/cmstypes.c:            // a = (Max ▒ Min) ^ ( 1 /
> Gamma)
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://If  R▒sRGB,G▒sRGB, B▒sRGB <
> 0.04045
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    R =  R▒sRGB / 12.92
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    G =  G▒sRGB / 12.92
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    B =  B▒sRGB / 12.92
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://else if  R▒sRGB,G▒sRGB, B▒sRGB
> >= 0.04045
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    R = ((R▒sRGB + 0.055) /
> 1.055)^2.4
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    G = ((G▒sRGB + 0.055) /
> 1.055)^2.4
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsvirt.c://    B = ((B▒sRGB + 0.055) /
> 1.055)^2.4
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Null transformation, only applies
> formatters. No cach▒
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// Gamut check, No cach▒, 16 bits.
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:// No gamut check, Cach▒, 16 bits,
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:            // Float transforms don't use
> cach▒, always are non-NULL
> ./supportApp/GraphicsMagickSrc/lcms/src/cmsxform.c:                    p ->xform =
> PrecalculatedXFORMGamutCheck;  // Gamut check, no cach▒
> PrecalculatedXFORM;  // No cach▒, no gamut check
> CachedXFORMGamutCheck;    // Gamut check, cach▒
> CachedXFORM;  // No gamut check, cach▒
> ./supportApp/GraphicsMagickSrc/magick/cdl.c: * Original implementation by Cl▒ment
> Follet.  Additional work by Bob
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToAbsolute() draws a
> cubic B▒zier curve from the current
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToRelative() draws a
> DrawPathCurveToQuadraticBezierAbsolute() draws a quadratic B▒zier curve
> DrawPathCurveToQuadraticBezierRelative() draws a quadratic B▒zier curve
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  B▒zier curve (using absolute
> coordinates) from the current point to
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  B▒zier curve (using relative
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToSmoothAbsolute()
> draws a cubic B▒zier curve from the
> ./supportApp/GraphicsMagickSrc/magick/draw.c:%  DrawPathCurveToSmoothRelative()
> ./supportApp/GraphicsMagickSrc/magick/hclut.c:%  GraphicsMagick by Cl▒ment Follet
> with support from C▒dric Lejeune of
> ./supportApp/GraphicsMagickSrc/wmf/src/extra/gd/gdtestft.c:  char *s = "Hello.
> ▒▒▒▒ɂ▒▒▒ Qyjpqg,";       /* String to draw. */
> Mark
> > From: Gofron, Kazimierz [mailto:[email protected]]
> > Sent: Saturday, February 17, 2018 11:59 AM
> > To: Mark Rivers <[email protected]>; [email protected]
> > character(s)
> > Could you please check if those characters are actually converted to UTF8 on your RHEL
> 7.
> > Form windows/linux google-chrome, I am seeing these characters in the github.com. I
> > copy/past them into the
> https://github.com/areaDetector/ADSupport/blob/master/supportApp/GraphicsMagickSrc/lc
> > ms/src/cmstypes.c#L965
> > I copy/past these characters into the UTF8 tool:
> > https://sites.google.com/site/nathanlexwww/tools/utf8-convert
> > I am seeing them as 6byte instead of usual 2Byte on the github.
> > From: Mark Rivers [mailto:[email protected]]
> > Sent: Saturday, February 17, 2018 12:48 PM
> > To: Gofron, Kazimierz; [email protected]
> > Subject: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
> > character(s)
> > Any idea why my RHEL 7 system behaves differently from your Debian 8 system?  Is it
> an
> > OS language setting?
> > ________________________________
> > From: Gofron, Kazimierz <[email protected]>
> > Sent: Saturday, February 17, 2018 11:35 AM
> > To: Mark Rivers; [email protected]
> > character(s)
> > Hi Mark,
> > The non UTF8 characters are seen on linux as well.
> > 1.       Debian 9 in VirtualBox on Windows 7 host.
> > kaz@stretch64:~/epics/ADSupport$ uname -a
> > Linux stretch64 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u5 (2017-09-19) x86_64
> > GNU/Linux
> > kaz@stretch64:~/epics$ git clone https://github.com/areaDetector/ADSupport ADSupport
> > Cloning into 'ADSupport'...
> > remote: Counting objects: 7063, done.
> > remote: Compressing objects: 100% (3/3), done.
> > remote: Total 7063 (delta 0), reused 1 (delta 0), pack-reused 7060
> > Receiving objects: 100% (7063/7063), 25.59 MiB | 3.38 MiB/s, done.
> > Resolving deltas: 100% (3660/3660), done.
> > kaz@stretch64:~/epics$ cd ADSupport/
> > kaz@stretch64:~/epics/ADSupport$ git branch -a
> > * master
> >   remotes/origin/HEAD -> origin/master
> >   remotes/origin/hdf5-1.10.1-pre1
> >   remotes/origin/hdf5-1.10.1-pre2
> >   remotes/origin/master
> > kaz@stretch64:~/epics/ADSupport$ grep -n -axv '.*'
> > 965:    //(see clause 4.1 for the definition of �aligned�). Because the Unicode language
> > 3063://The device representation corresponds to the header�s �color space of data�
> field.
> > 3064://This representation should be consistent with the �number of device components�
> > 3066://The PCS representation corresponds to the header�s PCS field. The PCS
> > representation
> > 3811://CIE �absolute� illuminant white point tristimulus values and CIE �absolute�
> > 3898:// The first curve segment always starts at �Infinity, and the last curve segment
> always
> > 4174:// array = [e11, e12, �, e1P, e21, e22, �, e2P, �, eQ1, eQ2, �, eQP, e1, e2, �, eQ]
> > 4673:            // Y = (Max � Min) * (X ^ Gamma) + Min
> > 4676:            // a = (Max � Min) ^ ( 1 / Gamma)
> > 2.       Server , debian 8
> > kgofron@xf18id-srv2:~/test/ADSupport$ uname -a
> > Linux xf18id-srv2 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19)
> x86_64
> > GNU/Linux
> > kgofron@xf18id-srv2:~/test$ git clone https://github.com/areaDetector/ADSupport
> > Receiving objects: 100% (7063/7063), 25.59 MiB | 5.94 MiB/s, done.
> > Checking connectivity... done.
> > kgofron@xf18id-srv2:~/test$ cd ADSupport
> > kgofron@xf18id-srv2:~/test/ADSupport$ git branch -a
> > * master
> > kgofron@xf18id-srv2:~/test/ADSupport$ grep -n -axv '.*'
> field.
> > representation
> always
> > Kaz
> > Sent: Saturday, February 17, 2018 11:40 AM
> > character(s)
> > Hi Kaz,
> > I cannot reproduce your grep of the non-UTF-8 characters.  Here is a fresh clone and a
> grep
> > on an RHEL 7 system.  The grep command is a copy and paste from your e-mail.
> > [epics@corvette scratch]$ git clone
> [email protected]:areaDetector/ADSupport<mailto:[email protected]:areaDetector/ADSupport
> > Receiving objects: 100% (7063/7063), 25.59 MiB | 29.57 MiB/s, done.
> > [epics@corvette scratch]$ cd ADSupport/supportApp/GraphicsMagickSrc/lcms/src/
> > [epics@corvette src]$ grep -n -axv '.*' cmstypes.c
> > What do you see if you follow these steps on a Linux system?
> > Mark
> > Sent: Saturday, February 17, 2018 9:31 AM
> > To: Mark Rivers <[email protected]<mailto:[email protected]>>; tech-
> > character(s)
> > Hi Mark,
> > After changing to master branch (was in detached HEAD), I confirmed that the
> cmstypes.c
> > has the UTF8 problem.
> > Sqr-1 IXS@IXS_MCM /cygdrive/c/epics/synApps/support/areaDetector-3-
> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src
> > 965:    //(see clause 4.1 for the definition of ▒aligned▒). Because the Unicode language
> > 3063://The device representation corresponds to the header▒s ▒color space of data▒
> field.
> > 3064://This representation should be consistent with the ▒number of device components▒
> > 3066://The PCS representation corresponds to the header▒s PCS field. The PCS
> > representation
> > 3811://CIE ▒absolute▒ illuminant white point tristimulus values and CIE ▒absolute▒
> > 3898:// The first curve segment always starts at ▒Infinity, and the last curve segment
> always
> > 4174:// array = [e11, e12, ▒, e1P, e21, e22, ▒, e2P, ▒, eQ1, eQ2, ▒, eQP, e1, e2, ▒, eQ]
> > 4673:            // Y = (Max ▒ Min) * (X ^ Gamma) + Min
> > 4676:            // a = (Max ▒ Min) ^ ( 1 / Gamma)
> > Now your steps:
> > -----------------------------------Step 1
> > c:\epics\synApps\support\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc
> > \lcms\src>git status .
> > On branch master
> > Your branch is up to date with 'origin/master'.
> > nothing to commit, working tree clean
> > ----------------------------------  Step 2
> > a)       {I do not have the O.windows-x64-static-vs2017 directory}
> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>ls -l
> > total 1240
> > -rw-r--r-- 1 Sqr-1 IXS 197121   1484 Feb 16 15:21 Makefile
> > -rw-r--r-- 1 Sqr-1 IXS 197121    945 Feb 16 15:21 Makefile.am
> > -rw-r--r-- 1 Sqr-1 IXS 197121  24192 Feb 16 15:21 Makefile.in
> > drwxr-xr-x 1 Sqr-1 IXS 197121      0 Feb 17 10:16 O.Common
> > drwxr-xr-x 1 Sqr-1 IXS 197121      0 Feb 17 10:16 O.windows-x64-static
> > -rw-r--r-- 1 Sqr-1 IXS 197121  16076 Feb 16 15:21 cmsalpha.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  14439 Feb 16 15:21 cmscam02.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  75151 Feb 16 15:21 cmscgats.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  43741 Feb 16 15:21 cmscnvrt.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  21630 Feb 16 15:21 cmserr.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  38551 Feb 16 15:21 cmsgamma.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  20565 Feb 16 15:21 cmsgmt.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  35846 Feb 16 15:21 cmshalf.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  45687 Feb 16 15:21 cmsintrp.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  60115 Feb 16 15:21 cmsio0.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  36128 Feb 16 15:21 cmsio1.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  53169 Feb 16 15:21 cmslut.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121   9806 Feb 16 15:21 cmsmd5.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121   5858 Feb 16 15:21 cmsmtrx.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  29205 Feb 16 15:21 cmsnamed.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  66034 Feb 16 15:21 cmsopt.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121 112503 Feb 16 15:21 cmspack.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  26406 Feb 16 15:21 cmspcs.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  28939 Feb 16 15:21 cmsplugin.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  48476 Feb 16 15:21 cmsps2.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  18399 Feb 16 15:21 cmssamp.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  19820 Feb 16 15:21 cmssm.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121 186719 Feb 17 09:34 cmstypes.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  38122 Feb 16 15:21 cmsvirt.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  11330 Feb 16 15:21 cmswtpnt.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  49131 Feb 16 15:21 cmsxform.c
> > -rw-r--r-- 1 Sqr-1 IXS 197121  22867 Feb 16 15:21 lcms2.def
> > -rw-r--r-- 1 Sqr-1 IXS 197121  37465 Feb 16 15:21 lcms2_internal.h
> > b)
> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del O.windows-x64-static-
> > vs2017\cmstypes.obj
> > The system cannot find the file specified.
> > c)
> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>make
> > make -C O.windows-x64-static -f ../Makefile TOP=../../../../.. \
> >     T_A=windows-x64-static install
> > make[1]: Entering directory 'c:/epics/synApps/support/areaDetector-3-
> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static'
> > perl -CSD c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl  -m cmstypes.d -I. -
> > I../O.Common -I. -I. -I.. -I../../../../../include/compiler
> > /msvc -I../../../../../include/os/WIN32 -I../../../../../include      -
> IC:/epics/synApps/support/asyn-
> > R4-33/include     -IC:/epics/synApps/s
> > upport/areaDetector-3-2/ADSupport/include/os/WIN32 -
> > IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include   -
> > t/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0.1/include/compiler/msvc -
> > Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-7.0.1/i
> > nclude     -I../../../../../supportApp/GraphicsMagickSrc/lcms/include    cmstypes.obj
> > ../cmstypes.c
> > Malformed UTF-8 character (fatal) at c:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl
> > line 137, <FILE> line 5573.
> > make[1]: Nothing to be done for 'install'.
> > make[1]: Leaving directory 'c:/epics/synApps/support/areaDetector-3-
> > a2)
> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>del
> > cmstypes.obj
> > 2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src\O.windows-x64-static>cd ..
> > ../cmstypes.c
> > cl               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -
> > D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3     -D_LCMSLIB_ -DWIN64
> > D_VIS
> > UALC_ -D_LIB    -MT    -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/msvc -
> > /../include      -IC:/epics/synApps/support/asyn-R4-33/include     -
> > IC:/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/WIN32 -I
> > IC:/epics/synApps/support/areaDetector-3-2/ADCore/include -Ic:/epics/base-7.0
> > .1/include/compiler/msvc -Ic:/epics/base-7.0.1/include/os/WIN32 -Ic:/epics/base-
> > 7.0.1/include     -I../../../../../supportApp/GraphicsMagick
> > Src/lcms/include    -c ../cmstypes.c
> > cmstypes.c
> > lib -nologo -verbose -out:lcms.lib         cmsalpha.obj cmscam02.obj cmscgats.obj
> > cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.ob
> > j cmsintrp.obj cmsio0.obj cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj
> > cmsopt.obj cmspack.obj cmspcs.obj cmsplugin.obj cmsps2.o
> > bj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj cmswtpnt.obj cmsxform.obj
> > Appending cmsxform.obj
> > Appending cmswtpnt.obj
> > Appending cmsvirt.obj
> > Appending cmstypes.obj
> > Appending cmssm.obj
> > Appending cmssamp.obj
> > Appending cmsps2.obj
> > Appending cmsplugin.obj
> > Appending cmspcs.obj
> > Appending cmspack.obj
> > Appending cmsopt.obj
> > Appending cmsnamed.obj
> > Appending cmsmtrx.obj
> > Appending cmsmd5.obj
> > Appending cmslut.obj
> > Appending cmsio1.obj
> > Appending cmsio0.obj
> > Appending cmsintrp.obj
> > Appending cmshalf.obj
> > Appending cmsgmt.obj
> > Appending cmsgamma.obj
> > Appending cmserr.obj
> > Appending cmscnvrt.obj
> > Appending cmscgats.obj
> > Appending cmscam02.obj
> > Appending cmsalpha.obj
> > Installing library ../../../../../lib/windows-x64-static/lcms.lib
> > My installation is cloned directly to Windows from github, but previously I cloned to
> > debian9 virtual machine, and copied through shared folder to Windows with same
> compile
> > errors. The compilation is reproducible on two Windows 7 systems.
> > -Kaz
> > Sent: Saturday, February 17, 2018 8:26 AM
> > To: Gofron, Kazimierz; [email protected]<mailto:[email protected]>
> > character(s)
> > Hi Kaz,
> > I just tested compiling that file on my system.  The following shows that I am using the
> git
> > master version of that file, and that I don’t get any error compiling it with VS 2017.  Can
> > you please execute these exact same 3 commands on your system?  Check out the master
> > branch first.  In the output below I inserted line breaks into the cl output to make it easier
> to
> > read.
> > One difference could be that my working directory is on a Linux system, not on a
> Windows
> > system.  I have the Linux file system mounted from the Windows machine.  Perhaps there
> is
> > some character translation happening either with the git checkout on Linux, or when
> serving
> > the files to Windows?
> > J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>git
> > status .
> > On branch master
> > Your branch is up-to-date with 'origin/master'.
> > J:\epics\devel\areaDetector-3-2\ADSupport\supportApp\GraphicsMagickSrc\lcms\src>del
> > O.windows-x64-static-vs2017\cmstypes.obj
> > make -C O.windows-x64-static-vs2017 -f ../Makefile TOP=../../../../.. \
> >     T_A=windows-x64-static-vs2017 install
> > make[1]: Entering directory 'J:/epics/devel/areaDetector-3-
> > 2/ADSupport/supportApp/GraphicsMagickSrc/lcms/src/O.windows-x64-static-vs2017'
> > -D_LCMSLIB_ -DWIN64 -D_VISUALC_ -D_LIB    -MT    -I. -I../O.Common
> > -I. -I. -I.. -I../../../../../include/compiler/msvc -I../../../../../include/os/WIN32 -
> > -IJ:/epics/devel/asyn-4-33/include/compiler/msvc  -IJ:/epics/devel/asyn-4-33/include
> > -IJ:/epics/devel/areaDetector-3-2/ADSupport/include/os/WIN32 -
> > -IJ:/epics/devel/areaDetector-3-2/ADCore/include -IH:/epics-devel/base-
> > -IH:/epics-devel/base-7.0.1/include/os/WIN32 -IH:/epics-devel/base-7.0.1/include
> > -I../../../../../supportApp/GraphicsMagickSrc/lcms/include    -c ../cmstypes.c
> > cmstypes.c
> > cmscnvrt.obj cmserr.obj cmsgamma.obj cmsgmt.obj cmshalf.obj cmsintrp.obj cmsio0.obj
> > cmsio1.obj cmslut.obj cmsmd5.obj cmsmtrx.obj cmsnamed.obj cmsopt.obj cmspack.obj
> > cmspcs.obj cmsplugin.obj cmsps2.obj cmssamp.obj cmssm.obj cmstypes.obj cmsvirt.obj
> > Appending cmssm.obj
> > "Installing library ../../../../../lib/windows-x64-static-vs2017/lcms.lib"
> > make[1]: Leaving directory 'J:/epics/devel/areaDetector-3-
> > Sent: Saturday, February 17, 2018 7:03 AM
> > character(s)
> > Hi Mark,
> > The ADSupport compilation error is originating from non compatible UTF-8 characters in
> > cmstypes.c file. That compilation error went away after changing characters to UTF-8
> > format.
> > For now, I placed a UTF-8 compatible file here:
> https://github.com/kgofron/synAppsRelease/blob/master/SCRIPTS/ADSupportRepair/cmsty
> > pes.c
> > I wonder whether you have another installation of GraphicsMagick on your system.
> > The characters not following UTF-8 format are on following lines of cmstypes.c file. I
> > checked few and they have 24 bit/6byte, instead of 2Byte(UTF-8). They are in comments
> > area, and typically are left-quote/right-quote, ellipses single character (…), elongated
> minus,
> > etc.
> > ms/src/cmstypes.c#L3063
> > ms/src/cmstypes.c#L3064
> > ms/src/cmstypes.c#L3066
> > ms/src/cmstypes.c#L3811
> > ms/src/cmstypes.c#L3898
> > ms/src/cmstypes.c#L4174
> > ms/src/cmstypes.c#L4673
> > ms/src/cmstypes.c#L4676
> > UTF8<=> converter
> > Line 965 1st non-compatible character uses left quote (Hex C293220A,
> RFC4648:wpMK).
> > -Kaz
> > Sent: Friday, February 16, 2018 11:46 PM
> > character(s)
> > >  There is a compilation error when compiling ADSupport  of areaDetector 3.2 with base-
> 7.
> > This error is related to GraphicsMagic.
> > I cannot reproduce that problem.  I have rebuilt ADSupport several times and the strings
> > “Malformed” or “UTF-8” do not occur in the output.  I used “make –sj8”.  I am using the
> > master branch of ADSupport.
> > I am using the same setup as Kaz:
> > base-7.0.1.1
> > VisualStudio 2017
> > make-4.2.1
> > Windows 7 Pro 64 bit
> > windows-x64-static
> > I do note that by switching to make 4.2.1 I no longer see the hangup when using “make –
> sj”
> > which I did see with make 4.1.  make 4.1 would always hang when building
> > ADSupport/supportApp/hdf5Src with with make –sj.  It did always work with make –sj8.
> > Mark
> > From: [email protected]<mailto:[email protected]>
> [mailto:tech-
> > [email protected]] On Behalf Of Gofron, Kazimierz
> > Sent: Friday, February 16, 2018 9:31 PM
> > To: [email protected]<mailto:[email protected]>
> > Cc: Gofron, Kazimierz <[email protected]<mailto:[email protected]>>
> > Subject: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8
> > character(s)
> > Hi,
> > There is a compilation error when compiling ADSupport  of areaDetector 3.2 with base-7.
> > base-7.0.1.1
> > VisualStudio 2017
> > make-4.2.1
> > windows-x64-static
> > When compiling ADSupport, the following error is displayed twice:
> > Appending buf.obj
> > line 136, <FILE> line 5573.
> > jbig.c
> > BZIP compiling as library
> > Kazimierz Gofron
> > NSLS-II Controls Group
> > Brookhaven National Laboratory
> > (p) +1 (631) 344 5283
> > (f) +1 (631) 344 8085
> > (e) [email protected]<mailto:[email protected]>
> > (w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Maren Purves
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Johnson, Andrew N.
ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Prev: RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
Next: Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
