> However, stream-2-7-7 (master) is not compiling
Try the master branch of StreamDevice. That is working for me with these fixes. I don't recall where I got the fixes to StreamBuffer.cc and I am not sure if they are necessary.
corvette:~/devel/stream/StreamDevice>git diff master
diff --git a/Makefile b/Makefile
index 247c705..c2b3a09 100644
--- a/Makefile
+++ b/Makefile
@@ -19,6 +19,6 @@ else
endif
endif
-DIRS += streamApp
+#DIRS += streamApp
include $(CONFIG)/RULES_DIRS
diff --git a/src/StreamBuffer.cc b/src/StreamBuffer.cc
index 3b34de3..6e25f7e 100644
--- a/src/StreamBuffer.cc
+++ b/src/StreamBuffer.cc
@@ -314,7 +314,7 @@ dump() const
StreamBuffer result(256+cap*5);
result.append("\033[0m");
size_t i;
- result.print("%"P"d,%"P"d,%"P"d:\033[37m", offs, len, cap);
+ result.print("%" P "d,%" P "d,%" P "d:\033[37m", offs, len, cap);
for (i = 0; i < cap; i++)
if (i == offs) result.append("\033[34m[\033[0m");
diff --git a/src/StreamCore.cc b/src/StreamCore.cc
index 1943bf1..ca59b6a 100644
--- a/src/StreamCore.cc
+++ b/src/StreamCore.cc
@@ -997,7 +997,7 @@ readCallback(StreamIoStatus status,
finishProtocol(ReplyTimeout);
return 0;
case StreamIoFault:
- error("%s: I/O error after reading %"P"d byte%s: \"%s%s\"\n",
+ error("%s: I/O error after reading %" P "d byte%s: \"%s%s\"\n",
name(),
inputBuffer.length(), inputBuffer.length()==1 ? "" : "s",
inputBuffer.length() > 20 ? "..." : "",
@@ -1006,7 +1006,7 @@ readCallback(StreamIoStatus status,
return 0;
inputBuffer.append(input, size);
- debug("StreamCore::readCallback(%s) inputBuffer=\"%s\", size %"P"d\n",
+ debug("StreamCore::readCallback(%s) inputBuffer=\"%s\", size %" P "d\n",
name(), inputBuffer.expand()(), inputBuffer.length());
if (*activeCommand != in_cmd)
> -----Original Message-----
> From: Gofron, Kazimierz [mailto:[email protected]]
> Sent: Friday, February 23, 2018 8:47 AM
> To: Mark Rivers <[email protected]>; 'Andrew Johnson' <[email protected]>; tech-
> [email protected]
> Subject: RE: Possible issue with epics-base 7 compilation
> I confirm, that when using make 4.2.1, I and am not seeing hanged 'cmd' session on
> Windows 7 Pro, or uncompleted compilations when using 'make -j' in Visual Studio
> Community Edition 2017.
> Compiled:
> base-7.0.1
> synApps (packages required by AD)
> AreaDetector 3-2
> perl -CSD C:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m pcre_refcount.d -I. -
> I../O.Common -I. -I. -I.. -I../../include/compiler/msv
> c -I../../include/os/WIN32 -I../../include -IC:/epics/synApps/support/asyn-4-33/include -
> IC:/epics/synApps/support/calc-3-7/include
> -IC:/epics/synApps/support/sscan-2-11-1/include -IC:/epics/base-
> 7.0.1/include/compiler/msvc -IC:/epics/base-7.0.1/include/os/WIN32 -IC:/epi
> cs/base-7.0.1/include pcre_refcount.obj ../pcre_refcount.c
> perl -CSD C:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m pcre_byte_order.d -I. -
> svc -I../../include/os/WIN32 -I../../include -IC:/epics/synApps/support/asyn-4-33/include
> -IC:/epics/synApps/support/calc-3-7/include
> pics/base-7.0.1/include pcre_byte_order.obj ../pcre_byte_order.c
> perl -CSD C:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m pcre_ord2utf8.d -I. -
> cs/base-7.0.1/include pcre_ord2utf8.obj ../pcre_ord2utf8.c
> perl -CSD C:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m pcre_jit_compile.d -I. -
> msvc -I../../include/os/WIN32 -I../../include -IC:/epics/synApps/support/asyn-4-33/include
> e -IC:/epics/synApps/support/sscan-2-11-1/include -IC:/epics/base-
> epics/base-7.0.1/include pcre_jit_compile.obj ../pcre_jit_compile.c
> perl -CSD C:/epics/base-7.0.1/bin/windows-x64-static/mkmf.pl -m pcre_chartables.d -I. -
> pics/base-7.0.1/include pcre_chartables.obj ../pcre_chartables.c
> Installing generic include file ../../include/pcre.h
> mkdir ../../include
> cl -DHAVE_MEMMOVE=1 -DNEWLINE=10 -
> DINT64_MAX="(0x7FFFFFFFFFFFLL)" -DLINK_SIZE=2 -
> DMAX_NAME_COUNT=10000 -DMAX_NAME_SIZE=32 -DMATCH_
> LIMIT=10000000 -DMATCH_LIMIT_RECURSION=MATCH_LIMIT -
> DPOSIX_MALLOC_THRESHOLD=10 -DPARENS_NEST_LIMIT=250 -
> DSUPPORT_PCRE8 -nologo -D__STDC_
> _=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -
> Ox -Oy- -W3 -MT -I. -I../O.Common -I. -I. -I.. -I../../include/com
> piler/msvc -I../../include/os/WIN32 -I../../include -IC:/epics/synApps/support/asyn-4-
> 33/include -IC:/epics/synApps/support/calc-3-7/
> include -IC:/epics/synApps/support/sscan-2-11-1/include -IC:/epics/base-
> -IC:/epics/base-7.0.1/include -c ../pcre_chartables.c
> pcre_chartables.c
> ../pcre_chartables.c(1): error C2059: syntax error: '.'
> make[2]: *** [C:/epics/base-7.0.1/configure/RULES_BUILD:230: pcre_chartables.obj]
> Error 2
> make[2]: Leaving directory 'c:/epics/synApps/support/stream-2-7-7/pcre/O.windows-x64-
> static'
> make[1]: *** [C:/epics/base-7.0.1/configure/RULES_ARCHS:58: install.windows-x64-
> static] Error 2
> make[1]: Leaving directory 'c:/epics/synApps/support/stream-2-7-7/pcre'
> make: *** [configure/RULES_DIRS:88: pcre.install] Error 2
> c:\epics\synApps\support\stream-2-7-7>
> - Kaz
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, February 22, 2018 2:36 PM
> To: 'Andrew Johnson'; Gofron, Kazimierz; [email protected]
> I mentioned this in another thread, but I respond here too.
> Using this 4.2.1 version I can now do "make -j" on my Windows 7 machine with various
> versions of Visual Studio (2010, 2015, 2017) and I have not yet seen a problem. With the
> previous 4.1 version it would always hang with make -j in the
> areaDetector/ADSupport/supportApp/hdf5Src directory. Make -j8 would work OK.
> I have now built all of base 7.0.1 and synApps (including asyn, seq, areaDetector) with
> make -sj with no problems.
> Mark
> > From: Andrew Johnson [mailto:[email protected]]
> > Sent: Tuesday, February 13, 2018 3:41 PM
> > To: Gofron, Kazimierz <[email protected]>; Mark Rivers
> > <[email protected]>; [email protected]
> > Subject: Re: Possible issue with epics-base 7 compilation
> > Hi Guys,
> > I don't know if an update will make any difference, but I just built a
> > copy of the latest GNU make 4.2.1 which you can download from
> > https://epics.anl.gov/download/tools/make-4.2.1-win64.zip
> > Please let us know if this helps.
> > - Andrew
> > On 02/12/2018 06:42 PM, Gofron, Kazimierz wrote:
> > > Hi Mark,
> > > Indeed it is make 4.1 from EPICS web page, that Andrew build.
> > > Kaz
> > > ________________________________________
> > > From: Mark Rivers [[email protected]]
> > > Sent: Monday, February 12, 2018 7:36 PM
> > > To: Gofron, Kazimierz; [email protected]
> > > Cc: [email protected]
> > > Hi Kaz,
> > > I don't think this is a new problem, and is not specific to EPICS 7.
> > > Are you using the
> > make 4.1 that Andrew built and put on the EPICS Web page?
> > > If I run "make -sj" with that version then it will occasionally get
> > > into a state when one
> > "make" process is using 100% of a core forever and it never completes.
> > This happens with 3.14.12.5, 3.15.5, and 7.0.1.1.
> > > I have never had a problem if I use "make -sj8" on my 8-core machine.
> > > Mark
> > > Sent: Monday, February 12, 2018 6:23 PM
> > > To: [email protected]
> > > Cc: Mark Rivers <[email protected]>; [email protected]
> > > Subject: Possible issue with epics-base 7 compilation
> > > Hi,
> > > There is a possible threading issue when compiling epics-base 7
> > > using 'make -sj' on 8
> > hyperthread system.
> > > Observed on System X 3250 M5 with 8 hyperthreads, running windows 7
> > > Professional,
> > Xeon E3-1230 v3, and Visual Studio 2017.
> > > make -sj never completes compilation make -sj4 completes compilation
> > > Compilation always successfully completes on Lenovo W550s laptop with 4
> hyperthreads.
> > > The two attached files show the two cases when compiling 'make' and
> > > 'make -sj' on the
> > System X 3250 M5 (8 hyperthreads).
> > > Kaz
> > Arguing for surveillance because you have nothing to hide is no
> > different than making the claim, "I don't care about freedom of speech
> > because I have nothing to say." -- Edward Snowdon
- Possible issue with epics-base 7 compilation Gofron, Kazimierz
- RE: Possible issue with epics-base 7 compilation Mark Rivers
- RE: Possible issue with epics-base 7 compilation Gofron, Kazimierz
- Re: Possible issue with epics-base 7 compilation Andrew Johnson
RE: Asyn not automatically reconnecting Daykin, Evan
Re: Asyn not automatically reconnecting Mark Rivers
<2018>
Other Access Security implementations? Ralph Lange
<2018>
