>Sorry if this is the wrong question, but what is asyn 4.33-2 ?
>"git tag" mentions R4-33, not "-2".
That's the revision in our debian repo, it is asyn 4-33.
> So from asyn everything seems to be OK.
Maybe this is streamdevice and/or our vendor's software. We will investigate both avenues.
-----Original Message-----
From: Torsten Bögershausen [mailto:[email protected]]
Sent: Tuesday, February 27, 2018 3:37 PM
To: Daykin, Evan <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Subject: Re: Asyn not automatically reconnecting
On 23/02/18 15:17, Daykin, Evan wrote:
> Hi Mark,
> Thanks for the reply. We are using asyn 4.33-2 and Stream 2.6-3. The
> protocol file has a ReplyTimeout of 2000ms.
And to answer the other question:
>Here's something interesting: asyn behaves correctly for us *only* when the >client application is killed with SIGKILL, rather than SIGTERM. This results >in TCP retransmissions and/or refused connections, then normal operation after >a short while. Is it possible asyn is [un]intentionally not retrying the >connection if it is closed gracefully?
The code that I see producing "Read from broken connection" is this:
/* If recv() returns 0 on a SOCK_STREAM (TCP) socket, the connection has closed */
if ((thisRead == 0) && (tty->socketType == SOCK_STREAM)) {
epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
"%s connection closed",
tty->IPDeviceName);
closeConnection(pasynUser,tty,"Read from broken connection");
And then
closeConnection(asynUser *pasynUser,ttyController_t *tty,const char *why) {
asynPrint(pasynUser, ASYN_TRACE_FLOW,
"Close %s connection (fd %d): %s\n", tty->IPDeviceName, tty->fd, why);
It seems that the problem described here:
>2018/02/23 09:51:47.089 test-rf-dcu-n0001.cts:5001 read.
>The last line then repeats rapidly forever.
is caused by the caller into asyn, which is streamdevice ?
There seem to be some improvements in streamdevice, but I am not familiar with the code.
Dirk, does there ring a bell ?
- Re: Asyn not automatically reconnecting Mark Rivers
- Asyn not automatically reconnecting Daykin, Evan
- RE: Asyn not automatically reconnecting Daykin, Evan
Re: Asyn not automatically reconnecting Torsten Bögershausen
<2018>
<2018>
