Whit:
At this time, MEDM is an orphan piece of software. There are no
developers assigned to maintain it. Fantastic that it still works and
is still useful. Great job to its developers! MEDM's true end of life
will coincide with that of MOTIF, which library it uses. Recently, some
have made code changes in response to specific problems, but MEDM has no
maintainer.
At the APS, we went through a decision process before making the
transition from MEDM to caQtDM. You might be interested in some of the
criteria we considered, as described in this PDF from 2013:
https://epics.anl.gov/bcda/Docs/2013-08-12-replace-MEDM-slides.pdf
One of the interesting criteria from that report is how each of the
display managers perform under heavy update load. Some of them have
built-in features to throttle the display update rate, even though
incoming PVs are updated faster.
Another criterion is the live display of 2-D images, such as a from a
camera.
Another criterion is the ability to move display objects based on EPICS
PV values (such as to animate the movement of some device relative to
others).
The decision to use caQtDM was based on many factors, one of the most
important was that we were currently using MEDM. In the end, it was
more important for us to maintain a consistent user experience between
MEDM and its chosen successor at APS. We started this transition last
year for the facility (XSD) beam lines, yet some of the XSD beam lines
still use MEDM.
One other aspect is that the synApps developers, who maintain software
used by many facilities beyond the APS, continue to write screens in
MEDM, then use adl2ui to convert them to caQtDM for local use. This
allows others to apply similar converter tools to translate the MEDM
screens for their Display Manager. Adding yet another display manager
(YADM, if I may) will increase this complexity further. One must
establish truly "good value" for YADM if its screens are to be shared
with others. Or a truly good translator from MEDM. Extra value if it
can translate between YADM, CSS, caQtDM, epicsQt, ... and all the rest
of the new ones.
Pete
On 2/28/2018 2:43 PM, Ryan Slominski wrote:
Whit,
I'm not a maintainer of MEDM, but I'm interested in display managers and maintain WEDM (https://github.com/JeffersonLab/wedm). I agree that Motif is an old technology and a proprietary file format requiring a custom parser and encoder isn't optimal today where most languages now provide XML and JSON support. However, the cost of creating and maintaining a display manager from scratch is high, and there are many existing ones already. So it is an interesting question whether it just makes more sense to use an existing one as requirements not met can usually be worked around. At JLab we mostly rely on EDM, but we create custom applications (in whatever language) for very custom screens.
Ryan
Hi Ryan,
That it is not a nightmare is one feature. MEDM is pretty great
considering how old it is, and it easy to compile/install.
IMO not looking like windows 95 would be a major improvement. Also, the
ability to easily add new displays, interfaces, and interface behaviors
is missing.
One thing that would be nice is if the "adl" format was something
standard like json. I have not looked at the MEDM code yet.
I have been looking for an excuse to play around with Dear ImGui. It
turns out that a display manager is an ideal use for it. ImGui is
written in c++ (actually it is written like c code). I don't care what
language is used but it is probably best to do everything in c++ for
speed purposes. There are a lot of wrappers for Dear ImGui.
Are you a maintainer of MEDM?
Cheers,
Whit
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- Re: Idea for new Display Manager Jameson Graef Rollins
- Re: Idea for new Display Manager Ryan Slominski
Re: Idea for new Display Manager Andrew Johnson
<2018>
<2018>
