Mark,
I recently deployed a GigE camera Mako G-234B from Allied Vision with the Prosilica Area Detector but noticed a bit of oddness with the expected frame rate. The camera data sheet lists 41.2 FPS as the readout rate,10-bit sensor readout but the Xml file from the camera shows feature(s) of
<Feature Name="AcquisitionFrameRateAbs" Type="Float" Access="R/W">31.872511</Feature>
<Feature Name="PixelFormat" Type="Enumeration" Access="R/W">Mono8</Feature>
<Feature Name="SensorReadoutMode" Type="Enumeration" Access="R/W">Readout12Bits</Feature>
Which is the frame rate which Area Detector seems to acquiring at.
I am assuming that I would have to implement “SensorReadoutMode” to be able to get the expected FPS, or am I missing an existing parameter that might already do this?
Me
