1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem building 3.15.5
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Tue, 13 Mar 2018 18:37:09 -1000
Thanks Andrew, you're correct!
(I actually even looked at one of those .d files)
Maren
On 03/13/18 18:29, Johnson, Andrew N. wrote:
Hi Maren,
You wrote “Before I changed the INSTALL_LOCATION to be outside the
source tree it built fine on linux-x86_64”. I suspect you didn’t do a
‘make clean’ when you added the INSTALL_LOCATION setting, and as a
result you have a lot of dependency files (*.d) in your
O.linux-x86_64 directories which depend on the old locations, i.e.
with the include directory inside the source tree. That explains why
the error message is from make (and not from gcc).
Try starting again from a clean source tree and I think (hope) you’ll
find the problem goes away.
- Andrew
problem building 3.15.5 Maren Purves
Re: problem building 3.15.5 Johnson, Andrew N.
Prev: Re: problem building 3.15.5 Johnson, Andrew N.
Next: Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: SMOO expects constant Amien Crombie
ANJ, 15 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
