1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem building 3.15.5
To: Maren Purves <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 14 Mar 2018 04:29:59 +0000
Hi Maren,
You wrote “Before I changed the INSTALL_LOCATION to be outside the source tree it built fine on linux-x86_64”. I suspect you didn’t do a ‘make clean’ when you added the INSTALL_LOCATION setting, and as a result you have a lot of dependency files (*.d) in your O.linux-x86_64 directories which depend on the old locations, i.e. with the include directory inside the source tree. That explains why the error message is from make (and not from gcc).
Try starting again from a clean source tree and I think (hope) you’ll find the problem goes away.
- Andrew
Sent from my iPad
> On Mar 13, 2018, at 9:34 PM, Maren Purves <[email protected]> wrote:
> Hi all,
> as we're getting a new receiver and we're talking soft IOC and
> the soft IOCs only started in 3.14 (and we're running 3.13.8
> otherwise) I have started looking at 3.15.5.
> tree it built fine on linux-x86_64 - source tree is
> /jac_sw/epics/src/base-3.15.5 and I would like it to build into
> /jac_sw/epics/R3.15.5/.
> This works to until I get to libCom/test, which ends in
> make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
>            T_A=linux-x86_64 install
> make[1]: Entering directory `/jac_sw/epics/src/base-3.15.5/src/libCom/test/O.linux-x86_64'
> make[1]: *** No rule to make target `../../../../include/epicsUnitTest.h', needed by `epicsUnitTestTest.o'. Stop.
> i.e. it looks for the include file in the source tree rather
> than in the install tree, where it does exist:
> ls -la /jac_sw/epics/R3.15.5/include/epicsUnitTest.h
> -r--r--r-- 1 maren software 1700 Mar 12 16:28 /jac_sw/epics/R3.15.5/include/epicsUnitTest.h
> Commenting out libCom/test I get something similar for ca/client:
> make -C ca/client install
> make[1]: Entering directory `/jac_sw/epics/src/base-3.15.5/src/ca/client'
> make[2]: Entering directory `/jac_sw/epics/src/base-3.15.5/src/ca/client/O.linux-x86_64'
> Installing generic include file /jac_sw/epics/R3.15.5/include/cadef.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/caerr.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/caeventmask.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/caProto.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/db_access.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/addrList.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/cacIO.h
> Installing generic include file /jac_sw/epics/R3.15.5/include/caDiagnostics.h
> make[2]: *** No rule to make target `../../../../include/dbDefs.h', needed by `cac.o'.  Stop.
> make[2]: Leaving directory `/jac_sw/epics/src/base-3.15.5/src/ca/client/O.linux-x86_64'
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory `/jac_sw/epics/src/base-3.15.5/src/ca/client'
> make: *** [ca/client.install] Error 2
> Am I missing redefining something somewhere in the configuration files?
> I looked through them and didn't find anything referencing INCLUDE that
> didn't also say INSTALL_LOCATION. We haven't built into source trees in
> the past and I would prefer not to start now.
> What am I missing?
> TIA,
> Maren
Re: problem building 3.15.5 Maren Purves
Prev: problem building 3.15.5 Maren Purves
Next: Re: problem building 3.15.5 Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 13 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
